Honda CR-V & Element 2WD & 4WD Element & CR-V
Radiator Fan needs "help" 2004 CR-V
Old Apr 1, 2016 | 12:49 PM
AdamRR's Avatar
Icon5 Radiator Fan needs "help" 2004 CR-V
My radiator fan does not always turn on and as a result, the engine will overheat. When this happens, I pop the hood and the just give the fan blades a little "tap" with my finger, and the fan motor starts right up and spins, and then the engine cools.
Two things I did recently (this was not happening before):
Replaced the starter (from below)
Drained the coolant and replaced with 50/50
Any suggestions? Is the motor bad? Could it be a sensor?
Old Apr 1, 2016 | 02:26 PM
UK-Kev's Avatar
Default Re: Radiator Fan needs "help" 2004 CR-V
If the fan motor is not sticking and you having to assist the motor to start it turning, I would suggest you can rule out the sensor because it sounds like you have an armature winding broken.
Kev
Old Apr 1, 2016 | 03:22 PM
AdamRR's Avatar
Thanks Kev. The fan motor moves very freely when I spin it when the motor is off.
I wonder if I may have damaged it somehow. While I was replacing the starter, I had an led flashlight/worklight propped next to the fan area. Do you suppose I may have disconnected something or ...?
Kev
Old Apr 2, 2016 | 04:24 AM
UK-Kev's Avatar
Have you tried putting a live feed and earth to the motor off engine?
Regarding your question – Led flashlight/work light propped cause the problem!!!! In my opinion no way would this cause any issues.
Kev
ANNADAD
Jul 30, 2014 12:51 PM
SGT_Manny
11
Jun 15, 2010 04:56 PM
m1ndless
Jun 25, 2007 06:43 PM
BHNTech
Apr 29, 2006 07:39 PM
TheMacGuy
Oct 12, 2005 05:24 PM
