TN 1990 Eagle Talon TSI AWD Turbo 5sp lots new
See ad here:
1990 Eagle Talon TSi AWD 5sp turbo fresh head runs great
** Price is $4000 **
The vehicle up for sale is a rare 1990 Eagle Talon TSi AWD 5sp turbocharged, clear title.
I have put alot of work into this vehicle, and it runs great! Most parts are new, or only 4k miles or
10k miles on them! This is a very nice talon that was built and tuned properly. Much more potential
can be seen from this with a turbo upgrade as the fuel system and engine will support much more power!
All-Wheel Drive Turbocharged 5speed manual transmission
Vehicle body has only 180k miles on it
Under the hood:
6-bolt big rod block (stock, great condition) and big-port head
Fresh headjob
New timing belt (gates), all timing pullies, tensioner, balance shaft belt, water pump
Upgraded valve stem seals
Upgraded 3g lifters
ARP head studs
EGR delete plate
Replaced throttle shaft seals
Non-cruise short throttle cable
Speed density conversion w/ 3-bar MAP, GM IAT sensor
Custom 3" air intake
New knock sensor
New coilpack
New NGK sparkplug wires, plugs
Manual boost controller with cermaic ball
Dodgemod custom modified stock blow-off valve - can run in race (holds up to 30psi) or street mode
Turbo/exhaust:
14b w/ 16g evo turbine housing @18psi
2g dsm turbo manifold ported, painted
Ported O2 housing
3" downpipe
Nice custom full 3" exhaust with 4" out muffler
Fuel:
Walbro 255lph HP fuel pump
Rewired fuel pump
EVO 560cc fuel injectors
-6AN fuel inlet/return lines, inline fuel filter
Adjustable fuel pressure regulator with gauge
Inside:
Vent 2-gauge pod
Innovate LC-1 Wideband o2
Glow shift boost gauge (much better than the autometer it replaced)
EPROM ECU socketed and wideband tuned on Jackal (speed density)
Battery relocated to trunk, recently replaced
Suspension/Wheels:
Mustang 16" wheels with 225 50 16 tires
KYB GR2 front struts with new strut caps
KYB AGX adjustable rear struts
Suspension techniques lowering springs
New lower balljoints
New inner and outer tierods
Miata-mod converted manual rack and pinion
Energy suspension polyurethane bushings
Transmission:
Stock AWD 5sp transmission in good shape
New seals on transfer case and axle seals on transmission
Lightweight chromoly flywheel
Stage 4 6-puck clutch
Brass shifter cable bushings
Aluminum shifter base bushings
Replaced clutch pedal assembly with no-play unit
New clutch master and slave cylinders
Aluminum solid driveshaft bushings
Penzoil synchromesh in transmission, Redline heavyweight shockproof in transfer case and rear diff
Cooling:
Aluminum radiator
Aluminum fan shroud w/ 2 x 12" slim fans
New radiator hoses (upper blue urethane, lower gates OE style), thermostat, rad cap, water pump
Silicone heater hoses
Aluminum coolant overflow tank
Brakes:
New brake master cylinder
Brakes recently redone front and rear, work great
Bad:
*Ebrake cable disconnected on driver side but adjusted cables to still work fine - caliper ebrake lever is frozen, but brakes work fine
*Some body damage on driver fender and light damage on side of body, comes with good shape replacement fender
*Interior descent shape, needs head liner, visors mis-matched, needs a plastic trim piece
*Stock radio, sometimes doesn't work but most will replace with aftermarket anyway
Under the hood:
Fresh headjob
Upgraded 3g lifters
ARP head studs
EGR delete plate
New knock sensor
New coilpack
Turbo/exhaust:
Ported O2 housing
3" downpipe
Fuel:
Rewired fuel pump
Inside:
Vent 2-gauge pod
Suspension/Wheels:
Transmission:
Cooling:
Aluminum radiator
Brakes:
Bad:
EvanED
Honda Civic (2001 - 2005)
11
Mar 29, 2010 06:05 PM
Travis10
Northern California (Sales)
13
Sep 11, 2006 09:42 PM
Travis10
Jul 19, 2006 09:23 AM
