Coolant problem
hey guys so im having a problem with my hatch it has a d15b7 in it and it keeps pushing coolant into the reservoir but its not loosing any coolant i pulled the plugs today and it didn't look like a blown head gasket cleaning the pistons and there is no oil in the coolant im thinking maybe the bleeder valve is letting air in somehow but im lost because im not loosing the coolant can anyone help thanks again guys
Even though it "keeps pushing coolant into the reservoir", the level of coolant in the radiator never goes down? sounds like you've read that this is usually a sign of a bad head gasket.
Let the car idle for a few minutes, take a sniff of the exhaust air. Does it smell like coolant and is there moisture on the tail pipe?
what i was saying was it pushes the coolant into the overflow and when i open the cap the coolant is at the top of the fins and when i pore the coolant that was in the over flow back into the radiator it fills it back up but i fixed it yesterday it was the hose to the overflow had a tear in it just big enough to suck air in but thanks guys
91civicsikid
13
Jun 24, 2014 03:23 PM
JDM_SOHC
21
Mar 18, 2010 10:14 PM
