brake problems? help!
Old Mar 30, 2016 | 05:52 PM
Bryson Seigler's Avatar
Default brake problems? help!
Hi guys , so for a while now.. my car has been sitting with bad brakes. my pedal goes straight to the floor when I push it. I checked the master cylinder & it was missing a nut & was leaking with rust down it so I pulled the old master cylinder off & replaced it with a new one.. bled all the brakes in order about 3-4 times & now it's still going straight to the floor.. what could be the issue? any ideas? Also , my brake lights stay on now & won't go off! I'm in the process of getting new pads , rotors & calipers for the front as they are needed. Thanks in advance!
Old Mar 30, 2016 | 06:15 PM
Former User's Avatar
Default Re: brake problems? help!
Did you bench bleed the new MC?
Cluster brake light or rear brake lights?
Old Mar 30, 2016 | 09:36 PM
I didn't bench bleed the master cylinder & it's the rear tail lights on the back.
Old Mar 30, 2016 | 10:29 PM
eghatch9295's Avatar
Stancetard Hate Monger
brake switch may be defective as to the lights. master cylinder needs bled.
CarBug
Jun 12, 2016 01:51 PM
5rivers
Oct 10, 2015 06:44 AM
ribal_gh
11
Apr 30, 2013 04:24 AM
SlammedEG6
Aug 16, 2010 12:46 PM
sobey
Mar 11, 2009 06:08 PM
