Can I use K20A3 motor from RSX auto for an SI?
Old Mar 30, 2016 | 10:38 AM
andresohc's Avatar
Default Can I use K20A3 motor from RSX auto for an SI?
I have a 2003 Civic SI EP3 that needs a new motor. Can I put a used RSX K20a3 auto engine in by switching the fuel and ignition systems from the SI? Also will this work with all the JDM K20a3 motos I see with similar fuel induction systems?
Old Mar 31, 2016 | 11:00 AM
turbohatchBnuts's Avatar
Default Re: Can I use K20A3 motor from RSX auto for an SI?
Yes you will need to change the drive plate out if it's still attached. Use the flywheel from the Si and the clucth.
Old Apr 3, 2016 | 08:29 PM
tabKola's Avatar
Switch the intake manifold and throttle body from the old motor onto the new one. Some of the JDM K20A non Type R engines have 3 lobe intake camshafts instead of 2 like the US K20A3s so those won't work with the stock Si ECU.
Old Apr 7, 2016 | 04:10 PM
Tonystark29's Avatar
this is true
lemongreenhatch
Jun 28, 2004 09:08 PM
mini-cRx
Mar 20, 2004 09:01 PM
Sam268
Feb 16, 2004 07:38 PM
shaved93integra
Feb 24, 2003 01:13 PM
Vtec Myrmidon
Dec 11, 2002 03:08 PM
