Hello i have the 2000 ls integra i have just had brake lines for rear replaced front to back as well as the fuel lines. currently i am looking into replacing the tank if necessary.
my question is are all integra 94-2000 gas tanks the same.
I found gas tank brand new on ebay $100 dollars shipped it says year 94-97
will this gas tank for $100 on ebay fit my car which is the model year 2000?
ok so check it out heres the tank and heres the filler neck will these work for my car its a 2000 ls two door online it says they fit 94-97 but im pretty sure they fit all, i dont wan buy it and get fuked tank $100 neck $50 with shipping. will the hose work with some regular clamps it says its 1 1/4 hose
You can navigate to the pages for the tanks for 1994 and 2000, and compare things like pumps, senders, straps, etc.
The straps are the same for both years, so a '94 tank may fit an '00 physically, but the EVAP systems are vastly different, so all the stuff that hooks up to the tank might not fit. Or maybe it will, if the numbers are the same.
i have done the work on my own i am just trying to see if anyone has come out with anything different. the link you posted the 94 integra fuel tank part number different from 00 integra part number but it is the same picture. so i am still at a loss, no where online can i find a fuel tank that says fit for 2000 acura integra. hope anyone in the midwest never has to replace their tank on 2000-2001 acura integra because there is just no straight answer on what tank fits what some say 94-2000 some say 94-97 and they all look the same in the picture.
All the brake pads are the same picture too, just saying.
I'm pretty sure you can go to a local junkyard, pull one off of any DC (a nice one) and buy it cheaper than 100$, most junkyards have 10day warranties in case it doesn't fit(ask first). I've done extracty that and now I only rely on junkyards for parts
If you asking if someone modified a 94-95 obd1 tank, or a 96-99 obd2a tank to fit a 00-01 obd2b integra than maybe you should've led with that instead of asking if all dc integra's share the same tank.
LEARN TO GET STRAIGHT TO THE POINT.
YEAH I DID GET STRAIGHT TO THE POINT IF YOU READ THE FIRST POST IT STATES "my question is are all integra 94-2000 gas tanks the same" SO I DONT KNOW HOW MUCH STRAIGHTER TO GET
ok please elaborate and tell me the differences and what would need to be modified first picture is 94-97 tank and second is 98-99 tank with those two pictures what would be the difference for the 2000-2001 models because the two pictures are the same and you are saying that the tank would have to be modified to fit a 2000 integra
please tell me the source of your information because i have been looking at this for days, the cars is at my friends garage and wont be able to drop tank to look at it until saturday
Reason: assholes talkin shit
i think the second picture is the one i need its 98-99 is what it says even tho they say it wont work for 2000 im gonna have to buy it, mine has screws just like it on bottem right
I JUST did a gas tank on my 92 Integra. A helpful hint, if you decide to replace your fuel pump, I very highly recommend an OEM with the wires and bracket. Now when I did mine, I actually re-used the original pump and just cleaned the hell out of the mounting bracket. I later had a no start issue that I thought was my pump but it was actually my ECU from parking the car in the rain only days after replacing the pump! Anyway. I had bought an aftermarket "lifetime warranty" fuel pump. It would prime but wouldn't run my car? Why? I'll never know. Spectra and Airtex make OEM assemblies, 130$ on ebay. I went with the Airtex. I have had no problems. I also had to cut out the metal lines behind the passenger wheel and replaced them with rubber because they were so corroded. The plastic plate protecting the lines holds a lot of dirt and gravel and causes moisture to eat through the lines. I also used the "fuel injector" clamps (i think that's what they call them) They are smooth style clamps that wont tear through the rubber lines.
ok well i got it down and looked at it, my integra has 3 holes in gas tank and not 2 like pictured above..... i guess i have ran out of hope. it is so fuked that i have so many problems finding parts for this car. people suggest get tank repaired, i live in small town they do not do that here and the closet junk yard with an integra is 2 hours away and by the time you get there it might be just as rusted. i have got so much money invested in this car it is ridiculous. thats what i get for getting a newer integra. why wouldnt honda just keep the same part number since in all integras are virtually the same. make a gas tank for a two year make is fuking ridiculous. what i get for buying an older car
Yes, the 00-01 Integra tank is different from the 94-99. How rusted could your gas tank possibly be? Is it just surface rust or are you a scrape away from leaking out gas?
It's not hard to find a gas tank for a 00-01 Integra if a replacement is really needed. Companies ship out parts everywhere...even to small towns.
bump if anyone can find a tank for 2000 or 2001 integra used or new i live in northwest indiana must be clean or if you find one online please post link i cannot find one other than dealership
ill update u some pics of the teg later this is my gs 2001 integra for now if you wanna look i got it pimped up in the engine bay just need a few more pieces here and there
having the same dilemma, 2001 gsr with a rusted tank leaking fuel when i fill up the tank..i already removed my tank having to cut a few corroded Evap lines (which will probably be the hardest part to get all back together, and crusty tank straps) i ordered a 99 fuel tank but turns out they only have 2 holes unlike the 00-01 which have 3 holes (3rd hole for a vent? ) so that had to be cancelled. I was lucky enough to locate one online (car-part.com as linked above {thanks Tamboo}) in a salvage yard about an hour up north from my area that was still in the car. i requested to have the complete tank with all components still attached and as much tubing that can be saved as well so hopefully it'll make the install a little easier which ill need all the time, effort and patience i can get.
