Gringo's 946whp/630ftlbs T3 .82A/R PTE 6466 Dyno
Old Mar 28, 2016 | 11:07 PM
gringotegra's Avatar
Default Gringo's 946whp/630ftlbs T3 .82A/R PTE 6466 Dyno
Well yesterday i got my car on the dyno and decided to see what the car is making now that i have and ECU that really controls everything!
Setup is as Follows
84mm GE Sleeved GSR Block
ITR Crank
Custom English Racing Spec Wiseco Pistons 10.7:1 compression
Manley Turbo Tuff Rods
ACL Rod/Main bearings
Step Decked Block NO O-Ring
JE Pro Seal Headgasket
Mission Critical Performance CNC Head
B16 Casting
GSC Power-Division Dual Valve springs/TI Retainers
GSC Power-Division T1 Turbo Cams
Ferrea Super Alloy Ex/IN Valves
Skunk 2 Ultra 4.5L Intake mani
Skunk 2 90mm TB
FIC 2150cc injectors
FIC Fuel Rail
Dual Grams 044 Fuel Pumps -8 Feed, Stock Feed as return line
Sumped Stock Tank
Extreme Turbo Systems Forward Facing Turbo manifold
PTE 6466 Turbo, T3 .82 A/R
Extreme Turbo Systems Intercooler 26x12x4"
Extreme Turbo Systems 3" Titanium Upper pipe
Dual MV-R Wastegates with 6psi WG springs
Motec M130 ECU With John Reed Racing/English Racing Honda M1 Package
Motec C125 Display Dash
Traction control, Dual 3-Port Boost controllers, Backpressure, oil pressure, Fuel pressure bla bla Bla.
RyWIRE Wiring harness
RaceGrade TC8 EGT
LTC 4.9 Wideband
RSX Coils
5 Bar Map sensor
Transmission is a 5 Speed Straight Cut Dogbox - Which i might add is my new favorite thing! lol
Comp Clutch Twin
Running on E80 (C16/E98 Mix) Been on this mix for over a year now
This is the same block that's been assembled in my car for almost 3 years now. The head has been on there for 2 so far.
Car just flat out makes power, every time.
After TX2K i just needed to see how much power it was making. I had ran more boost there than i ever had before.
Got the car on the dyno, and the results were:
48psi spike drops to 43psi. Peak power at 8800rpm 946whp and 630ftlbs@6600rpm . EBP 1:1@8800 after that it climbs to 1.26:1 by 10,000.
I didn't get the full graph up but after 8800 its not really that great. It actually drops about 200whp by 10k.
I didn't mess with cam timing on the dyno but i will be later this week. Hoping to move the powerband a little to the right since i finish the 1/2 mile close to 10k i need some power there!
Old Mar 28, 2016 | 11:27 PM
extremeracer's Avatar
Default Re: Gringo's 946whp/630ftlbs T3 .82A/R PTE 6466 Dyno
Saw this on Facebook ! Your car is crazy Myles and keeps delivering knock-out results.
Well done to you and everyone involved !
I thought you were planning on switching to a 64mm Xona - did that plan change ?
Old Mar 29, 2016 | 01:11 AM
KevinEF7's Avatar
Came in for the video.... disappointed
Old Mar 29, 2016 | 05:13 AM
Schister66's Avatar
Man U FTW
Saw this on Facebook - glad you brought it back to HT though. I always wondered what the little Teg made and i was not disappointed
Needs more turbo Time for EFR 9180?
Old Mar 29, 2016 | 06:08 AM
scottcraft's Avatar
10 Year Member
Loved
Community Favorite
I've seen some videos on YouTube of this car from tx2k16. Quite an impressive car!
Old Mar 29, 2016 | 07:08 AM
Dark_Teg's Avatar
I love the way your builds stay together at those power levels. Someone knows what they are doing.
Old Mar 29, 2016 | 07:22 AM
sdbee84's Avatar
Old Mar 29, 2016 | 07:27 AM
LightningTeg's Avatar
Community Builder
Old Mar 29, 2016 | 09:55 AM
This block has been assembled for almost 3 years now, head has been on for 2. Kinda surprised its still going myself lol
Eh per what i have seen, the 9180 makes LESS power than a 6466 on an Evo. Yes it has a bigger powerband but does not make the power.
Video will be up today Don't you worry
Old Mar 29, 2016 | 06:44 PM
Turbo-LS's Avatar
What kinda base pressure are you running on the fuel system Myles ? That's a bunch of power on a single set of 2200's and e80. Love your car bro. So well setup and it works ! Keep at it !
Old Mar 30, 2016 | 08:51 AM
TRY_HARDER's Avatar
Wow very impressive
Old Mar 30, 2016 | 02:31 PM
Tony the Tiger's Avatar
Talking about representing the Honda community in the big leagues, and with a B-series
The reaction from the R8 owner was pretty entertaining... He got hurt there pretty badly. It's another example that a 3500+ lb R8 will need about 1200-1300 WHP to square things up with a lighter car, more redline and one shift less during the race.
Old Mar 30, 2016 | 07:26 PM
DC-2uned's Avatar
Good **** as always Gringo, nice run against the R8! It's been great following the progress of the car, slowly watching it become the beast it is now. Congrats and keep it up!
Old Mar 30, 2016 | 09:06 PM
I fucked up man, i have a fucked up powerband now huh
I can deff say i never thought this ****** would make the torque it did lol
Running 43psi base actually.
Thanks man!!
Old Mar 30, 2016 | 09:42 PM
ss_zoidberg's Avatar
Time to update the sig there boy
Old Mar 31, 2016 | 07:19 PM
Totally did! lolo
Old Mar 31, 2016 | 09:32 PM
Geis's Avatar
Holy **** man! I saw that vid a week ago, you've done the 1/2 mile runs as well too right?
Never knew you were a member on honda tech, awesome build
Old Apr 1, 2016 | 05:39 AM
Schister66's Avatar
Man U FTW
Not just a member, an OG HT'er from '05.
Old Apr 2, 2016 | 05:10 AM
sdbee84's Avatar
Old Apr 3, 2016 | 08:31 PM
sdobart's Avatar
Interested to learn more about mixing leaded race gas and e85/98. From everything I've read, it is counterproductive as the metals in the leaded fuel remove much of the anti-detonating properties of ethanol.
Old Apr 4, 2016 | 05:48 AM
Flr Power's Avatar
I don't see how it would. Perhaps you can post a link that explains it.
Old Apr 6, 2016 | 08:10 AM
95B18BTurbo's Avatar
Myles, what are the specs and price on your dog box? You can PM me if you do not want them openly expressed.
Old Apr 6, 2016 | 08:32 AM
I have heard this before, but have never experienced it. I have had the car on this mix for years, and so have many other cars here at our shop.
Old Apr 6, 2016 | 10:06 AM
ShinsenTuner's Avatar
No Jodas
Saw this on 1320 video recently... bad ***. "So... is this an H22?" lol
Old Apr 6, 2016 | 11:43 AM
1HGEJ2's Avatar
wow great!
