95 accord condenser fan
Old Mar 28, 2016 | 08:57 PM
RC Senn's Avatar
Default 95 accord condenser fan
Got the 95 2.2 non v tech accord f22. My cooling fan is working properly but condenser fan isn't working at all. With that being said you can apply direct power from the battery to the fan and it works. I've used a test light at the engine side harness to check for power and I am getting it but not past the connection point on the fan side. I tried using jumpers behind both connections as a form or direct wiring without cutting out connectors and I still get nothing. I was told something about a fan timer switch?! Are there 2? Again the cooling fan is working properly so that would narrow down the diagnosis. Any help would be much appreciated. Thanks.
Josap_CD5
Mar 2, 2016 12:58 PM
ZillaG
May 5, 2013 12:38 AM
GLOCKIT
Aug 24, 2007 06:41 PM
blackdude
May 24, 2004 03:43 PM
blackcd
Nov 27, 2003 12:13 PM
