Wilwood DPHA and 9.4" calipers
Has anyone done this? I have 15x6.5 Mugen MF10's and there is no way that wheel is clearing. It rubs on the center hub. I'm just wondering, is there any wheel that will clear these brakes or should I upgrade the knuckle to go to 10.2?
DPHA are designed for 10.3" discs, I recommend you either buy the adapters that fastbrakes sells to enable the usage of calipers designed for 10.3/11.1" discs on 9.4" knuckles or change your knuckles.
I know they came with the bigger discs, but the bolt pattern for the knuckle would not line up because the size of the rotor pushes the caliper away from the mounting bracket. So they make an adapter? How reliable is it? Is it the same footprint for the caliper or do they make another caliper for 10.2?
