1989 Wago wont start. Need HELP
Old Mar 25, 2016 | 10:29 AM
mrboompow's Avatar
Default 1989 Wago wont start. Need HELP
Ok so i bought a 1989 Civic Wagon. Car is in great shape dude told me all it needed was a starter, distributor & the ignition switch to be hooked back up. So the 2nd day i was messing with it and it would push start just fine and run just fine no problems asked. With the key all the dash lights come on but just a click. Wont crank or anything. Well i bought a new starter put it in and still just clicking. And sometimes all the dash lights start flashing randomly until i turn the key off. Fuel pump is priming for sure, battery is good, starter is good. ive checked the ECU, IG, starter signal fuses and they are all good. Honestly i am dumbfounded and cant find a solution. Please someone help
Old Mar 25, 2016 | 03:04 PM
Sikocivic's Avatar
Default Re: 1989 Wago wont start. Need HELP
Check your grounds. Should be 1 on tranny, 1 near the thermostat housing and the 1 on the valvecover.
Old Mar 30, 2016 | 09:50 AM
jonGSR's Avatar
I would take a look at the ignition switch wiring. Possibly the wagon had an alarm and they cut into the power wires on the ignition switch. I had this happen to me in a 90 civic si. They had cut the wire because the alarm required it to run through the brain and once the alarm was removed they never reconnected the wires. Let us know if you find the problem.
Old Mar 30, 2016 | 04:37 PM
tamboo's Avatar
10 Year Member
clean ignition switch contacts, springs are likely ok.
see page 2:
DIY Ignition switch cleaning - Team Integra Forums - Team Integra
Old Mar 30, 2016 | 07:04 PM
Modusoperandi's Avatar
I had a similar problem and it ended up being the ground near the thermostat.
Old Apr 2, 2016 | 02:56 PM
89brokendownEF's Avatar
if its not a ground wire check to make sure your battery terminals are tightened securely
mrboompow
Mar 25, 2016 04:34 PM
redEFsocal
Jan 31, 2010 06:12 PM
dizzyroc88
Nov 17, 2005 08:22 AM
