96 Civic EX 5-speed/D16Y7 swap - intake, speedo, hood latch, exhaust questions
Old Mar 25, 2016 | 06:36 AM
cyclezach's Avatar
Icon7 96 Civic EX 5-speed/D16Y7 swap - intake, speedo, hood latch, exhaust questions
Hey Everyone, New to the world of Honda ownership. Just bought a 96 Civic 4 door with "132000" miles on it. Long story short, this is a "Get Out Of Debt Special" that needs to last me at least 3 years.
This is my first Honda to own after owning: 95' Sentra SE (GA16DE, MT, drover over 150k miles, 2004-2008), 93' NX2000 (SR20DE, MT, Drover over 100k miles, 2008-2013), 13' Forte 5 (EX, 2L, AT, selling to get out of debt).
I am mechanical skilled and am an engineer by trade, both Nissan's received new Engines by my hand.
So this 96 Civic had to of started life out at a EX (truck says EX, and it has a power sun roof), but at some point had a D16Y7 put in it (I think, the engine that is in there is not VTEC and has a down flow Intake Manifold). It also has a cheap @ss Ram Air intake installed.
I plan on doing a Timing Belt replacement just to be sure it'll last me these next 3 years. I've already fixed a few issues, and have a short list of thing to fix.
Long post for 4 simple questions:
1. The intake that is in there looks like it has a place for a Intake Air Temp sensor, but I cant find one in the engine bay at all. It runs fine as is, but if it should have a IAT sensor, then I would like to find it and get it installed correctly. So where on the Wiring harness/engine bay should I look for the IAT plug/sensor?
2. Speedo will only work about half the time. I plan on cleaning the plugs for the sensor at the engine and the cluster this weekend. If that dose not fix it what else should I look for? Would a Junk Yard Cluster be worth looking at? (My old Sentra had the same issue so that's why I think it probably has over 132k on it)
3. The hood latch wont latch the hood all the way down. Should i just loosen the bolts and move the bracket up? Also that hood rubs on that cheap RAI. Anyway to adjust how high the hood sits?
4. Any other issues that is common on these cars that I need to keep an eye on?
Thanks in advance for the help,
Zach
Old Mar 25, 2016 | 06:48 AM
Former User's Avatar
Default re: 96 Civic EX 5-speed/D16Y7 swap - intake, speedo, hood latch, exhaust questions
Manual or auto transmission?
Post the engine block and head codes.
https://honda-tech.com/honda-civic-d.../#post48684945
What CEL codes are thrown and what ECU is installed?
The stock EX IAT sensor connector would dangle somewhere above the VSS.
Post pictures of the hood issue.
Old Mar 25, 2016 | 06:56 AM
cyclezach's Avatar
Manual Transmission. Wont be close to the car until this afternoon, I'll see if I cant find the Engine Black and Head codes.
No CEL thrown, the only dash light that is on is the SRS. Not to worried about the Airbag systems just yet.
I'll have to look around the VSS to see if any plug is sticking out for the IAT.
How can you tell what ECU is installed? Where is it located on this vehicle?
Thanks!
Old Mar 25, 2016 | 07:08 AM
mk378's Avatar
Check that the CEL comes on for bulb test when you turn key on but don't start. Pretty common for someone to have removed the bulb. Definitely change timing belt on any newly acquired Civic, the job is very simple on these cars. You may consider going back to stock intake for better filtration, less noise, and hood clearance. Yes if the hood doesn't latch fully, move the latch until it does. Also the two rubber bumpers at the sides of the hood may be adjusted up too high, preventing hood from going all the way down.
Old Mar 25, 2016 | 07:29 AM
Might be a simple problem. Start by pulling the SRS code:
https://honda-tech.com/honda-civic-d...lists-1901557/
It's a 2P connector. Do a Google search for the 96-00 Civic service manual and download it.
Remove front passenger kick panel to expose the ECU. Post picture of label afixed to ECU to identify.
Old Mar 25, 2016 | 08:26 AM
cyclezach's Avatar
Thanks Guys!
I'll check the ECU number,Engine number and Manifold Numbers when I get home.
If the CEL is removed what bulb should I replace it with?
Thanks,
Zach
Old Mar 25, 2016 | 08:32 AM
I'll check the ECU number,Engine block and Head Numbers
Fixed
Temporarily move one of the other cluster warning light bulbs to the CEL position to pull the codes.
Example benefit of having the service manual:
Old Mar 25, 2016 | 03:59 PM
cyclezach's Avatar
Photo up load.
Old Mar 25, 2016 | 04:03 PM
D16Y7 block and head and matching P2E ECU
Any CEL codes?
Old Mar 25, 2016 | 04:57 PM
cyclezach's Avatar
Haven't gotten around to that just yet. The CEL is missing. Will pull the cluster tomorrow so I can do it.
Old Mar 25, 2016 | 06:19 PM
cyclezach's Avatar
New question, I have not had time to research this yet. But whith the head lights on the instrument cluster goes dark. No matter how much you turn the dimmer.
Old Mar 25, 2016 | 06:23 PM
How about the parking lights switch position?
Old Mar 25, 2016 | 06:34 PM
cyclezach's Avatar
No go. The panel only lights up when the headlight ms and parking lights are off! Blown fuse?
Old Mar 25, 2016 | 06:35 PM
Test the light switch. See FAQs sticky.
Old Mar 26, 2016 | 06:59 AM
cyclezach's Avatar
I can't find anything about the light switch in the sticky. Can you point me in the right direction?
Old Mar 26, 2016 | 09:35 AM
mk378's Avatar
Dash lights ON when the switch is OFF suggests that you've lost the ground. I think there is a big ground lug behind the cluster. This will also cause other instrument problems though.
Old Mar 26, 2016 | 04:20 PM
Combination switch
Old May 5, 2016 | 08:50 AM
cyclezach's Avatar
Got the issue with the dash figured out. Had to bypass the dimmer switch completely.
Said screw it on getting the Odometer/Speedo working. Instead I just use an app on my phone.
Timing belt has been replaced, and the car is driving nicely now. Had to pull the wiring harness out of the Driver side door to re-do the splicing job the previous owner did. Now all of the windows and Power Door locks work!
Bad thing is that I'm missing the AC idler pulley bracket. So no AC until I can make it by a Junk yard.
So new question, Is it normal for the D16Y7 with the stock exhaust to be extremely loud inside the car when pass 1/2 throttle? With the windows down, no load, the exhaust sounds like it should (I think) when revving it. But on the interstate at 75 MPH (~3500 rpm) the car requires about 1/2 throttle to maintain speed, but at this throttle setting its so loud that you have to shout at the passenger to have a conversation. Is this normal?
I had an 4-2-1 Header and a full 2" exhaust with a 18" glass pack, and a Mangnaflow muffler on the 200SX and it was quieter than the Civic is.
Old May 5, 2016 | 10:20 AM
Dimmer - Pick up a replacement at a junk yard.
Speedo - CEL codes? Corroded pins in VSS connector?
Exhaust noise - Check for exhaust leaks (holes, cracks, gaskets) and loose cracked exhaust heat shields.
Old May 5, 2016 | 10:31 AM
cyclezach's Avatar
Dimmer- I just crimp connected the wires together so the dash lights work at night. I always set those dimmers to the max brightness anyways.
Speedo- At one point in time I posted the CEL codes. All of them where for A/T except High AIT and High Primary O2 reading. No CEL code for VSS. Most times the Speedo will come to life and die a few times on my 30 min commute to work.
Exhaust noise- Ill have to check for that. Just looking under the car everything looks like it is in working order. Would it be advisable to find the time to pull the exhaust down and replace the gaskets? That way I can see all around the entire system? i also noticed the the exhaust look to be much smaller than the exhaust tunnel. Dose this mean that I'm missing some heat shields?
Thanks,
Old May 5, 2016 | 10:37 AM
Post (i) pictures of the exhaust system and (ii) all CEL codes (those that return after an ECU reset).
Old May 5, 2016 | 11:32 PM
eghatch9295's Avatar
Stancetard Hate Monger
these engines commonly crack around the primary oxygen sensor on the manifold, could be increasing the noise a bit. at the age of the car, i highly doubt you still have an oem gasketed exhaust system. your goofy intake will make some noise as well. you should have an iat sensor, but the intake arm they used does not have a provision for one. my guess is that they just left it hanging somewhere. i'd find a used oem intake setup and go that route, option 2 is to drill the aluminum arm.
Old May 6, 2016 | 05:45 AM
cyclezach's Avatar
Photo dump. Definitely looks like not a stock exhaust, but stockish looking that someone hacked together.
AIT sensor in the crappy intake.
Guessing this weld could be the source of the loud exhaust?
Old May 6, 2016 | 06:19 AM
mk378's Avatar
That looks like stock EX exhaust up to the catalytic converter, then someone cut the flange off of the back end of the converter, welded on a pipe and started doing their own thing all the way to the back of the car.
The DX and LX have the converter at the front of the engine. The combination manifold/converter is prone to crack. You don't have that system though.
To find exhaust leaks, idle the engine and have someone block the tailpipe with a rag while you go around listening under the hood and under the car. If there is a small to medium leak it will change from a putting sound to a hiss.
Putting a stock intake / air filter box back on will make the car quite a bit quieter.
Old May 6, 2016 | 06:29 AM
Your exhaust system is missing the resonator chamber in exhaust B (see diagram). The resonator works in conjunction with the muffler to reduce exhaust noise.
