Suspension & Brakes Theory, alignment, spring rates....
96 Itr brake help. Where to find 25t bracket?
Old Mar 25, 2016 | 12:48 AM
SupremeDalek209's Avatar
10 Year Member
Default 96 Itr brake help. Where to find 25t bracket?
Hi just need new rotors for my car, and obviously running 114.3 I have problems finding parts. Yet all I want to know is where to get 25t brackets. I read online that those will fit perfectly with usdm ITR front calipers + 25t brackets over prelude 11 inch rotors. Cheers
Old Mar 25, 2016 | 12:54 AM
10 Year Member
Default Re: 96 Itr brake help. Where to find 25t bracket?
https://honda-tech.com/suspension-br...-info-2642918/
this guy says 25t works with no modifications
Old Mar 25, 2016 | 05:23 AM
Fitz Williams's Avatar
10 Year Member
Look on Accords, 95-97 with V6, or any wagon and on 95-98 Odyssey. The 25T is used with the 282mm rotor. For the Legend GS and NSX, they use the 28T.
Old Mar 25, 2016 | 12:50 PM
Calif_Kid's Avatar
When I needed to get a set of 25T brackets, instead of going to my local Pick & Pull, I instead went to a wrecking yard specializing in Honda/Acuras where they had already pulled many of the parts off of the cars. I then just sifted thru the large pile of brake brackets until I spotted a few good 25T brackets. I'm not sure if you're looking for used brake brackets, but if you are, and there is a place with the brackets already pulled off of the car near you, then it might be a good way to go. - Jim
Old Mar 25, 2016 | 10:46 PM
10 Year Member
Yea I was looking for used parts online, but never thought of going to a place like that thank you. I am just so used to shopping online and pick n pull lol
Old Mar 25, 2016 | 10:47 PM
10 Year Member
Thank you appreciate it!
95lscivic
Dec 14, 2009 05:37 PM
endlesswinterco
Suspension & Brakes
May 15, 2008 07:13 AM
Understeer
Dec 15, 2003 10:26 PM
