Cut my harness when I shouldn't have. Junkyard fix?
Old Mar 24, 2016 | 07:00 PM
Dorkenheimer's Avatar
Default Cut my harness when I shouldn't have. Junkyard fix?
Doing my first swap. For some crazy reason, I thought I had to cut my driver side harness that runs into my engine bay. I drive a 93 Si. Will I be able to just head to the junkyard and pull another driver side harness from any other trim level EG, or will it have to be an Si/Ex?
Old Mar 26, 2016 | 03:59 AM
94EG8's Avatar
Seagull Management
Default Re: Cut my harness when I shouldn't have. Junkyard fix?
The short harness that runs from just inside the firewall to the driver's side headlight and washer tank? The only one that's a direct fit is from an Si. An EX/LX will work but you'll lose the wiring for the rear washer pump, DX will work but you'll lose the cruise control wiring. Anything else will work but you'll lose both cruise and the rear washer.
Old Apr 4, 2016 | 10:03 AM
Thanks for the response. I forgot I even posted this. I got spare from a friend and deleted all that clutter anyway, cause racecar. I made a new post regarding my current situation in the 92-00 civic section.
LaOXXKIDD
Mar 12, 2010 05:11 PM
ZAKU
Nov 18, 2008 04:15 PM
rwcdrums
Oct 10, 2004 11:27 AM
goforbroke
Apr 5, 2004 09:25 PM
