Honda Fit Wheels
Hey guys, I just bought a set of 2009 Honda Fit wheels
Google say that Honda fit center bore is 54mm
Civic = 56.1mm
And I saw a lot of people with Honda fit wheels on their Honda.
Will it fit, or I need to runs some spacers
Thanks in advance
Civic = 56.1mm
Thanks in advance
Aren't they like a +55 offset?
They're probably stolen wheels anyways.
And pretty sure the 2009 Fit only offered alloy wheels in 16". The base fit had 15" hubcaps.
They will fit with no problem make sure they are 16" you tire size should be 205 50 R16 which Honda recommend on Honda 7th generation (01 05). The 6th generation civic the bolt pattern is still 4x100 but you have to check the tire size. Hope this help.
