Lsv help
Can't find much infor on what throttle cabke bracket do I need to use for lsv and if I need to use a different cabke as well. It has a b16 head with skunk2 pro intake. The p75 bracket bolt holes dont line up with the intake nor fit because it hits the intake air temp sensor
i believe they now make custom throttle brackets. as for the throttle cable, you can possibly use the OEM LS cable. if not then just order a type r throttle cable online and get the matching throttle cable bracket
Autoworks
Mar 10, 2005 04:19 PM
