drivers door won't lock w/key
I've googled around but just get a bunch of results for power lock problems.
Has anyone had this happen and fixed it? I can unlock the drivers door with the key but it won't turn to lock it, just started doing this yesterday. I lubricated the lock and no luck.
What did you use to lubricate the lock? I use some graphite into the cylinder and it makes it nice and smooth. Did someone try to opening it with a screwdriver as in trying to steal the car? If so, I could be damaged a little.
I've had this same issue and now finally, I fixed the problem. In between the latch was a rubber piece that was blocking the window from shutting. I took a knife and cut some of it out.. And boom! It shut closed. I hope this the same issue you are having so you can close it. Thank me later 😅✌
