EF sedan rear eye LCA - rear fork compatility?
Old Mar 19, 2016 | 04:49 AM
Walterronny's Avatar
Default EF sedan rear eye LCA - rear fork compatility?
Im thinking in to change Rear eye LCA that use my EF sedan 88 with Rear fork LCA, it's just to replace shock and LCA with any modification?
Old Mar 19, 2016 | 06:31 AM
thescr33nn4m3's Avatar
Default Re: EF sedan rear eye LCA - rear fork compatility?
There are some companies that make aftermarket LCA that use the rear eye.
F7ITRLCA-SP - Function7 Integra Type-R/JDM Billet Lower Control Arms with Spherical Bearings | Function7 Engineering
Old Mar 19, 2016 | 06:55 AM
I dont want aftermarket LCA, just need to change shocks in EU LCA fork are more common than rear eye LCA.. was wondering if using EF rear fork Oem LCA will fits perfectly with any modification on EF sedan 88..of course with the correct rear shocks.
Old Mar 19, 2016 | 07:18 AM
4drEF's Avatar
Keyboard Humorist
I used the box/eye style on my 91 sedan.
Same style as found on the 88 crx and ITR.
Apparently, JDM integra had this style as well.
They bolt right in and shock mounting location in the same as stock.
Bonus - You also get holes for a stock sway bar. (Extra work needed to get sway bar mounts to bolt to chassis)
Old Mar 19, 2016 | 07:33 AM
All JDM Civic/CRX/Del Sol 88-95 use the rear eye. My 90 SiR has the eye style
JDM ITR's 94-01 use the rear eye as well.
And the USDM 88 Civic if i'm not mistaken.
They are all interchangeable.
Personally, i'd just keep the rear eye since it's not super uncommon and they make aftermarket LCA's if that is a route you chose to go in the future.
But to answer your original question: Yes you can switch to the fork style and get the correct LCA and it will not require any further modification to work.
Old Mar 19, 2016 | 08:16 AM
Ok, thanks!
Old Mar 19, 2016 | 11:30 AM
Tyson's Avatar
Same. Pics of 88 LCA
88 arm comparison to 89+. (should be same as ITR)
Other LCA comparisons.
https://honda-tech.com/suspension-br...cs%5D-2800903/
impreziv
18
Feb 18, 2015 01:02 AM
chase7687
Suspension & Brakes
Nov 3, 2009 06:48 AM
88 EF Hatch
Apr 5, 2009 08:28 PM
b16crx1
Jun 6, 2004 02:22 PM
Blown90hatcH
Oct 24, 2001 01:45 PM
