1998 Honda Accord 2.3 RPM's out of control
Old Mar 18, 2016 | 09:31 AM
bustedTaiLight's Avatar
Default 1998 Honda Accord 2.3 RPM's out of control
Changed plugs, wires, air filter, fuel filter, were on the 3rd used idle air control valve and the RPM's still jumping. Now my mechanic wants to try changing the throttle body. Heres a
. What do y'all think?
Old Mar 18, 2016 | 12:17 PM
poorman212's Avatar
Default Re: 1998 Honda Accord 2.3 RPM's out of control
Does the CEL come on and go off when the key is turned to on? Or just go have a parts store confirm there are not codes, most parts stores outside of the country of CA will do this for free.
Next, be sure the hoses to the IAC are clear and flowing. Then be sure to properly bleed the air from the cooling system.
These are just some "starter" points. There is much more we can get into if these test out.
Old Mar 27, 2016 | 02:30 PM
brent.'s Avatar
Originally Posted by bustedTaiLight
Changed plugs, wires, air filter, fuel filter, were on the 3rd used idle air control valve and the RPM's still jumping. Now my mechanic wants to try changing the throttle body. Heres a video of the car in action. What do y'all think?
mass air flow sensor been checked? normally when they are bad rpms jump around a lot
Old Mar 27, 2016 | 03:10 PM
poorman212's Avatar
You do realize/know the 98 4 cyl's do not have a mass air flow sensor?
Old Mar 28, 2016 | 02:21 AM
holmesnmanny's Avatar
Its just a vacuum leak. Find leak. Fix leak. Dont waste money replacing parts.
Old Mar 28, 2016 | 03:32 AM
trm4life's Avatar
I don't know about 98, but my 92 has an IACV (Idle Air Control Valve) and an EACV, also known as the electric idle control on my trouble code list. (Code 14) On my car it's on the back of the intake manifold, with 2 small coolant hoses and a 2 wire plug. May be as simple as your throttle cable being too tight, but I kinda doubt it. A check engine code would help
popeye2917
Oct 23, 2018 03:38 PM
Dannyshen2001
Aug 22, 2017 08:33 AM
funkyvailchick
Honda CR-V & Element
Oct 1, 2014 10:31 AM
sgull
Jun 29, 2013 01:01 PM
kailapics
Honda Civic (2001 - 2005)
12
Feb 4, 2013 01:46 AM
