Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission damage am I getting Screwed
Old Mar 17, 2016 | 09:22 AM
myboyshjstuff's Avatar
Post Transmission damage am I getting Screwed
I have been told I need my transmission is damaged and needs to be replaced but after many recent repairs and lots of money I am wondering if the damage caused to transmission could be related to repairs done. or parts replaced such as the O-ring etc. Please see photos attached for a list of repairs. Please help!
Here is my story:
I recently had approx $4000 worth of work done on my Acura. My car was starting to show signs of a small oil leak so I took it in and was told it had too many oil leaks, front & rear seals,valve cover, Gaskets etc. because the work was going to be so much we asked the mechanic to really go over it with a fine tooth comb and tell us if it would be worth the investment. I love this car it has been a really good car with little to no problems but did have 208,000 miles on it but I would rather fix it than take on a new car note if it was worth the investment. other than the oil leak it was running perfectly fine. after a week long valuation and looking at the prior repairs he said in his opinion it would be worth it. So after approx 4 weeks in the shop and the following repairs (please see pictures for list of repairs) I pay and pick it up! 3 days later took it back because it was driving funny the motor felt like it was running alot rougher and when I would push on the gas nothing would happen from time to time etc. also wanted them to check because it appeared that there was water(?) leaking from it even when it was up for the night in the garage. They replaced the oxygen sensor and said they could find no leaks. I picked it up a week later and though it was not having that issue as much, I did let them know that it felt like the engine was giving a little kick or jumping when I started it. I also had an episode where when I went to start it it would not start until several trys. It just wasnt driving as smoothly as it did before all the repairs. took it back for 1 more week at that point to have the ballist replaced and to have them take another look but said everything looked fine. So I dismissed it to just being in my head because I had been without my car for 6 weeks and forgot how drove.Well 1 week after getting it back my Transmission totally failed. I had to have it towed in. Totally sick to my stomach and in tears They said they added some transmission fluid and an additive and that was probably the problem but then called back later that day and said I needed a new transmission to the tune of approx $3500-$4000.
Old Mar 18, 2016 | 01:11 AM
Aquafina's Avatar
Default Re: Transmission damage am I getting Screwed
From the paperwork they didn't touch the transmission. The quote for a transmission is extremely high if they're just replacing it with a used transmission that hasn't been rebuilt.
Old Mar 20, 2016 | 05:04 PM
v4lu3s's Avatar
RTFM
Wouldn't the transmission come out for the rear main seal?
Old Mar 20, 2016 | 05:33 PM
lmananT's Avatar
The repairs already way exceed the value of the car, not worth it in my opinion.
Old Mar 21, 2016 | 02:34 AM
Aquafina's Avatar
Yes, but the transmission doesn't get split open and rebuilt, only removed from the engine.
Old Mar 21, 2016 | 07:10 AM
motoxxxman's Avatar
I don't see anything in there related to the transmission at all. it may or may not be coincidence that the transmission just failed.
the way you describe it running after you picked it up though makes me think they installed the timing belt incorrectly. it should have run exactly the same or better than when you dropped it off. not worse. and the symptoms you describe are pretty accurate for if one or more cams was 1 tooth off.
Old Mar 21, 2016 | 10:19 AM
king06's Avatar
They got you bad, sorry to say. Definitely don't spend any more money on this. For $4000 you better be getting a brand new in the box trans from honda. Also, for the $4000 you paid, you could of have a complete newer swap.
myboyshjstuff
Acura TL, RL & ZDX
Jul 13, 2016 08:20 AM
mononina22
Oct 11, 2013 03:09 AM
dohc notec
Acura TSX
75
Mar 22, 2013 09:26 PM
zero708970
Nov 7, 2008 06:10 AM
H0nda1
Feb 25, 2007 10:22 PM
