Transmission & Drivetrain Gearboxes, Differentials, Clutches
Car won't go in gear!!
Old Mar 17, 2016 | 08:41 AM
Richief12's Avatar
Default Car won't go in gear!!
I've got a 99 civic with Gsr swap it was always a bit hard to shift into gear so I had a type r transmission at home that I knew was good so put that on with new clutch flywheel throw out bearing and pressure plate drove the car for a week everything was perfect and then it started being hard goin into gear again (with the type r tranny this time) about 5 minutes later I couldn't get it into any gear at all and the pedal stuck to the ground clutch fluid was about half way down so I though maybe it was something in the hydraulics I replaced slave cylinder and master cylinder and the line bleed it again and still nothing. Does anyone have any ideas on what it could be I really need my car running again. Thanks!
Old Mar 18, 2016 | 01:13 AM
Aquafina's Avatar
Default Re: Car won't go in gear!!
Hydraulic system, clutch assembly, transmission, mounts/linkage.
Old Mar 18, 2016 | 02:16 AM
Richief12's Avatar
Changed the whole hydraulic system the other day and I have all new clutch assembly my transmission is good I have almost new solid motor mounts only thing I didn't change was shift linkage I'm just waiting on it coming In
Old Mar 18, 2016 | 04:10 AM
Black R's Avatar
25 Year Member
It won't go into any gear?
Play with the clutch engagement point at the pedal shaft then.
Or does the pedal drop to the floor and stay there?
Old Mar 18, 2016 | 07:48 AM
Richief12's Avatar
Won't go into any gear when the car is on but it will when it's shut off , I've tried adjusting the master cylinder but didn't seem to make a difference and no it has lots of pressure now with the new hydraulic system ,with the old master cylinder the pedal did stay on the floor.
Old Mar 18, 2016 | 07:50 AM
Aquafina's Avatar
Follow the Helms manual for pedal adjustment as Black R suggested. If that doesn't fix it then you have a problem with the transmission. Problems like this generally aren't caused by the linkage, but it is quick to check.
Old Mar 18, 2016 | 08:03 AM
Richief12's Avatar
Alright I'll try adjusting it again but I know for sure its not my transmission because I drove in the car that it came out of , it even done this with my Gsr transmission and I thought it was bad but I took it apart and it was fine. I know my clutch isn't disengaging because if I put it in gear while it's on and turn it on the car lurches forward
Smokeless
Jun 29, 2019 04:38 PM
anti muscle
Mar 10, 2011 10:56 AM
kwint
Nov 9, 2007 03:26 AM
93dx
Feb 3, 2005 02:40 PM
GIANT
Oct 27, 2004 08:14 PM
