Slipping clutch fix...
Old Nov 6, 2002 | 09:05 PM
Tommy_Gunns's Avatar
Default Slipping clutch fix...
What is the cheapest possible way to fix my slipping clutch?
My original plan was to get a new flywheel along with a complete clutch package (pressure plate & disc) but I am in a financial bind at the moment and need a more economical solution.
Can I just change out the worn disc and re-surface the flywheel?
Any advice much appreciated.
Thanks.
Old Nov 6, 2002 | 09:07 PM
sackdz's Avatar
Default Re: Slipping clutch fix... (Tommy_Gunns)
Yea, that will work, so long as your peepee is still in good shape.
Old Nov 6, 2002 | 09:22 PM
Paste's Avatar
Loved
Default Re: Slipping clutch fix... (sackdz)
your pp, heh
EDIT- i read somwhere that resurfacing the FW is not good, is this true or no?
[Modified by paste, 11:23 PM 11/6/2002]
Old Nov 6, 2002 | 10:00 PM
Now the question is, what disc should I buy that is compatible with the stock ITR PP?
Old Nov 6, 2002 | 10:09 PM
92cx's Avatar
i've been told that atleast for sohc honda's the exedy 99 dollar standard replacent basic organic clutch or whatever it is, is exactly the same as oem... as in thats where it comes from, as for flywheel just examine it when you pull it if it's still smooth no need to resurface, it's just like brake pad, people will tell you different but thats the truth, i've never bothered to have one resurfaced cause they always ok when i have it apart
Old Nov 7, 2002 | 05:15 AM
Asahi's Avatar
Default Re: Slipping clutch fix... (92cx)
How many miles on your slippiong disc? Tried adjusting the clutch throw a little so you can save for the flywheel? Might not work but free.
Old Nov 7, 2002 | 09:47 AM
Teepo's Avatar
Default Re: Slipping clutch fix... (Asahi)
take the flywheel to a good machine shop, get act s/s disc and get the pilot and throw out bearings. flush clutch fluid and you got yourself a nice freakin clutch.
friscorep
Dec 19, 2006 06:56 PM
aZnjCC
Mar 6, 2006 07:09 AM
vishyncsu
Oct 7, 2004 10:38 AM
BoostedIntegra
Jan 15, 2004 07:59 AM
Mark
Jun 4, 2003 03:35 PM
