Misc. Integra Leftover Stock Parts Garage Sale
Old Mar 15, 2016 | 01:25 PM
mazdabish's Avatar
Default Misc. Integra Leftover Stock Parts Garage Sale
Everything has to go, can be picked up at East Elmhurst, NY 11370 or I can meet you near Edison, NJ 08837. All parts are from a 1998 Integra GSR 4dr, tan leather interior/cypress green unless otherwise listed. Buyer pays for shipping, I'd rather you pick it up though. Cleaning out my garage for spring.
PM me if you're interested in anything for my contact info.
Other parts not shown: H22A4 OBD2 Alternator, (3) 4x100 Original Honda Spares, ABS Pump, Rear Driver's Glass + Regulator, 98 Civic EX Exhaust Manifold w/out cracks, I'll add those later.
Integra Power Steering Pump, Lines, Reservoir - $60. Rack is included...just really wouldn't use it (cracked housing).
Left Headlight - $20
Radiator Overflow - $10
Column Assembly and Leather Wheel/Airbag, has matching set of keys for ignition - $100
Full Size OEM Integra Radiators, used, fan included - $20 each
ABS Brake Booster and 1" Master Cylinder - $70
Eibach Racing 0600.250.0600 (2.5" Diameter 6" Tall 600lb Springs)- $70 for the pair
Integra Subframe - $70
Integra 13mm Rear Swaybar - $40
Tub of A/C parts, everything you'll need to add A/C back into your car if you regret deleting it (condenser, drier, lines, etc everything minus compressor) - $80
H23A1 Non-VTEC/Prelude Si Intake Manifold Lower Plenum - $20
Stock Integra Radio, has minor crack on corner. Should work, might have radio code somewhere - $10
OEM Jacks in various states - $10
OEM Tan Pass Airbag - $20
Vibrant 3" SS N1 Style Turbo Muffler with Hangers, silencer got stuck inside so I ended up opening it up to make it straight through - $40
Cypress Green Rear Pass Door - $30, has some scratches on it that may/may not buff out especially on handle, Not including door cards. Pickup only
Cypress Green Front Pass Door - $60, not including door card, pickup only.
Tan Center Console and Interior Bits - $40 since I'm missing the ashtray for the armrest
Engine Fuse Box/Harness - $40
Cluster Surround - $10
Stock Fuel Pumps and Assembly - $20
Handbrake, Dash Trim - $10
Glovebox - $20
Left Turn Signal Lamp - $20
Manual Pedals - $60
ABS Computer - $20
Tan Leather Door Cards - $80 for set of 4 in good shape, could use some reconditioning.
teg97
Southeast (Sales)
Jan 8, 2013 01:24 PM
chriszal1
Jun 28, 2011 03:12 PM
AutoFabProductions
Mar 22, 2005 07:19 AM
