Recommendations for shocks on my Del Sol
Old Mar 14, 2016 | 10:06 PM
R.Bush Mechanic's Avatar
Default Recommendations for shocks on my Del Sol
Need some recommendations for shocks on my Del Sol.
Not looking for race performance as i am daily comfort performance.
Smoother the car rides the better. Currently on stock
springs and suspension. Planning on swapping out
control arms and springs a little down the road as well.
Anything to help absorb the road. I can't lower the car as I
often put way to much weight in the car with tools and parts.
Thanks for the opinions guys!
Old Mar 15, 2016 | 03:57 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default re: Recommendations for shocks on my Del Sol
Bilstein HD shocks are likely your best bet. Cost effective and they work well with stock springs. Should be about $450-500.
If you can handle a 1" drop, Tein street basis coilovers are about the same price. The spring rates are a bit higher than stock..so adding extra weight shouldn't be an issue.
Either choice will ride as good...or better than stock.
Old Mar 15, 2016 | 04:26 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Recommendations for shocks on my Del Sol
if all you're after is oem ride height and a smoother ride, start replacing bushings, etc. monroe sells a product called "quick strut", which comes with a new strut, tophat, bump stop, and spring already installed. just start replacing worn parts.
dhoff024
Oct 6, 2009 01:30 PM
Non-Vtec101
Suspension & Brakes
Jun 13, 2008 12:14 PM
e1delsol
Jun 23, 2005 05:49 AM
YwanaV8
Suspension & Brakes
Feb 7, 2005 07:29 AM
