B20vtec h/c, supercharger?
Hey guys best supercharger for all motor b20v I would like to be around 350hp
I still need to build my b16 head going to put skunk2 pro 2 cams.
I have a friend that will sell me a jrsc that is used for $1500 but I'm not looking for cheap I'm looking for power and reliability.
You don't have a lot of options. The old honda engines spin backwards, it's more complicated to engineer a supercharging kit and they're not exactly common.
Procharger and kraftwerks make b-series superchargers. The procharger kit allows you to run a/c whereas the kraftwerks doesn't. I don't know the pros and cons compared to a turbo though.
I'll reword this. What would be the best supercharger for a b20 vtec motor with high comp pistons plus plans to cam it with pro 2 cams I want to keep my p/s and a/c and would like to push around 350hp.
Any supercharger and give you these #'s, you need to think about the block and head.
Maintenance on any USED kits is something that should not be 2nd guessed.
The Jackson Racing "B" series kit cannot make 350 wheel HP. If you want to keep A/C and P/S, the only choice at this point would be a ProCharger kit. They are officially discontinued although I hear contacting the company directly and begging may convince them to build you a kit. If that doesn't work, you will have to find one on the used market. Also, that much cam is no good for ANY supercharger kit. Pro 1's work well with the Rotrex based kits.
