Clutch acting weird 96 accord.
Old Mar 11, 2016 | 01:24 PM
04compg's Avatar
Default Clutch acting weird 96 accord.
Before anyone says I don't know how to drive stick lol I also have a 92 accord 318k miles currently, I picked up this 96 because it is so clean and hoping to get 300k out of it too, I just can't figure The clutch out its weird, sometimes it grabs right off the floor and then sometimes it grabs at the last moment and makes it easy to kill..the clutch feels strong (will chirp tires into second) so I don't think it's a bad clutch. Any advise?
Old Mar 11, 2016 | 02:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Clutch acting weird 96 accord.
There is probably a leak.
Open the hood and look down where the slave cylinder is. Pull back the boot and look for any wetness. Follow the hard line back to the soft line to the clutch master cylinder on the firewall. Again look for wetness. Verify the fluid in the clutch master cylinder is full. Verify it is clean. Has the clutch been bled correctly?
Push your driver seat all the way back, look under the dash and look for the rod that attaches to the clutch pedal. Look at the boot it goes into, verify it is not wet. If it is the clutch master cylinder is failing and will need to be replaced.
Old Mar 11, 2016 | 04:58 PM
04compg's Avatar
I think that's it! Under the dash the rod is wet, after replacing should I have it vacuum bled? Or can I do a two man bleed?
Old Mar 13, 2016 | 12:58 PM
Accordian47's Avatar
10 Year Member
You should be able to bleed the clutch system with just the two man, vacuum would work too, probly quicker and would guarantee more air is removed plus you can do it yourself, but hey either is good.
doughboi904
Dec 9, 2011 12:43 PM
smetzger
Mar 2, 2006 10:50 AM
ggoodspeed
May 17, 2004 03:17 AM
Thrillhouse
Dec 22, 2003 05:06 PM
Thrillhouse
Dec 22, 2003 09:02 AM
