How long to charge a battery at idle?
Old Mar 9, 2016 | 08:27 PM
johnson384's Avatar
Default How long to charge a battery at idle?
I've got a semi new battery (about 3 months old) but the water pump went out on my '91 honda civic and it's been sitting for a while so the battery is dead and needs to recharge.
I can't run the car at cruising speed because it starts to overheat but it can idle forever.
How long will it take to charge it with the alternator at idle?
I've idled for about 2 or 3 hours and it still wouldn't start again when I turned the car off.
Thanks,
-Tyler
Old Mar 9, 2016 | 09:35 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: How long to charge a battery at idle?
sounds like your alternator is weak. check your voltage while engine is running. should be about 14v. From a jumpstart, i can start the car again .5 to 1 hour of idle time.
that or you have alight on somewhere like the trunk.
you should post in the 88-91 EF fourm though.
Old Mar 10, 2016 | 06:27 AM
eghatch9295's Avatar
Stancetard Hate Monger
you should pull the battery and charge it.
Old Mar 10, 2016 | 07:48 AM
hondur's Avatar
Dur Da Dur
5 Year Member
You should probably repair your vehicle so it doesn't over heat while you're driving it. And bring the battery & alternator to a car parts store to have them tested.
Old Mar 10, 2016 | 05:58 PM
Grahambo02's Avatar
What the folks above said.
I had a similar issue and found that the actual battery cable clamps were crappy and weren't holding correctly. FWIW, New clamps fixed my charging issues.
Old Mar 12, 2016 | 01:44 AM
v4lu3s's Avatar
RTFM
Alternators do a poor job at charging batteries, but a great job at maintaining charge. Most parts stores will test and charge batteries for nothing.
afnan
Apr 14, 2014 04:23 AM
wteebo
Honda Civic (2001 - 2005)
Sep 3, 2013 05:25 PM
motegicivic
May 6, 2012 12:02 AM
Slammed Ek9
Apr 9, 2005 07:39 PM
bluesaint
Mar 6, 2003 09:38 AM
