Transmission & Drivetrain Gearboxes, Differentials, Clutches
how do i measure to shim a diff
Old Mar 9, 2016 | 05:30 AM
ls-t eg's Avatar
Default how do i measure to shim a diff
I put together a trans with some parts I had from old transmissions I had and I was told I have to measure and shim the diff to keep it from walking. I cannot find a write up on this and would like to do this so I don't damage the trans. Thank you in advance for any info.
Old Mar 9, 2016 | 02:42 PM
Aquafina's Avatar
Default Re: how do i measure to shim a diff
Slide a feeler gauge in between the diff bearing and shim. You want a max of .04" with ball bearings. Tapered bearings require a special tool to check the preload. It is all in the Helms manual and there are several how-to's that have been posted in here.
Old Mar 9, 2016 | 10:11 PM
ls-t eg's Avatar
I just ordered a Chilton's manual today cause I keep having to refer to Google for simple **** like this. I don't have a shim in there yet, so would I just put a feeler gauge in between the diff bearing and case to see what shim I need?
Old Mar 9, 2016 | 10:12 PM
ls-t eg's Avatar
I'm sorry for the stupid questions, I have searched and can't find anything on this and don't want to assume I'm doing it right and screw something up.
Old Mar 9, 2016 | 11:23 PM
kr3w108's Avatar
DIY: Transmission Rebuild (89pics!)
Scroll to post #4 you can use this as a guideline on how to check, The measure measurements should come from the service manual for the correct type of trans.
Old Mar 10, 2016 | 12:26 AM
ls-t eg's Avatar
Thank you very much. That's exactly what I was looking for.
Old Mar 10, 2016 | 11:47 AM
Aquafina's Avatar
Having a shim in there is the best way, but is not necessary.
Luded93
Apr 20, 2011 11:32 PM
hondaZvic
Apr 21, 2009 09:27 PM
turbo_d
Feb 7, 2009 07:22 AM
89Si
Dec 28, 2003 08:09 AM
