5 speed manual Tranny swap from 94 del sol to 94 civic ex
Old Mar 8, 2016 | 12:33 PM
94delsolcivic's Avatar
Icon5 5 speed manual Tranny swap from 94 del sol to 94 civic ex
Hello everyone,
I need some help please.
I have a functional 94 del sol 5 speed manual transmission (A000 series) that I want to put it into a 94 civic ex with a B series 5 speed manual transmission (my first gear is grinding). Is this a doable swap?
Thanks,
Les
Old Mar 8, 2016 | 01:00 PM
Former User's Avatar
Default Re: 5 speed manual Tranny swap from 94 del sol to 94 civic ex
Are you asking whether you can mate a B-series engine with a D-series transmission?
Old Mar 8, 2016 | 01:07 PM
I was hoping that I could replace my existing tranny on my civic ex 1.6, which the first gear is starting to grind and my clutch just went out, with a tranny from my del sol 1.5 to save from buying another tranny. The del sol tranny is a left over from my daughter's crashed del sol. The clutch is the same on both trannys. But, I didn't know if there would be any complications with the bolt pattern or any tranny support parts.
Old Mar 8, 2016 | 01:18 PM
24TEN's Avatar
PHANTOM MENACE
Since you're not answering it directly if you are attempting to bolt on a D transmission to a B engine (or vice verse) it will not work without spending money on an adapter plate setup (very costly).
Old Mar 8, 2016 | 01:41 PM
Thank you for your response.
My engine on the civic ex is a D16Z6 with a 5 speed manual transmission, series no. S20 B000.
The del sol engine is a D15B7 with a 5 speed manual transmission, series no. S20 A000
The clutch sizes are identical.
So my question is: will the del sol tansmission from a 1.5 engine fit on a civic ex 1.6 engine?
Both are D series engines,
trannys are:
del sol A000 series
civic EX B000 series
Old Mar 8, 2016 | 01:59 PM
I believe the swap will work, but the gearing of the two transmissions is different. The EX transmission is the best match for the D16Z6.
Old Mar 8, 2016 | 03:07 PM
Thank you all for your help...I appreciate your time!
Old Mar 9, 2016 | 07:58 AM
Eh2Guanaco's Avatar
D series tranny will not bolt up to the B series block...unless you go spending some money on a D2B kit...which it will be pointless
Old Mar 9, 2016 | 10:16 AM
24TEN's Avatar
PHANTOM MENACE
Thank you for reading the thread. /sarcasm
Old Mar 11, 2016 | 06:34 AM
94EG8's Avatar
Seagull Management
Yes it will work, but the gearing will longer.
Old Mar 11, 2016 | 06:36 AM
tony_2018's Avatar
Fish Twig
Your title is misleading than. THE ANSWER IS NO its not possible to do a straight replacement.
Old Mar 11, 2016 | 01:51 PM
94EG8's Avatar
Seagull Management
The title isn't misleading but some of the first post is. What the OP wants to do is very doable. He does not have a B-series transmission, what he's been referring to as a B-series transmission is an EX/Si D-series B000 (Big Bearing) transmission which I'm surprised no one seems to be picking up on.
Old Mar 12, 2016 | 08:49 AM
tony_2018's Avatar
Fish Twig
My bad
Title misleading from subject
Old Mar 13, 2016 | 01:43 PM
Kerry Miller's Avatar
are you parting out the Del Sol?
liljlw1991
Sep 8, 2011 04:32 PM
mo_thug_85
Mar 17, 2009 06:31 PM
sorullo
Jul 7, 2008 09:35 PM
spcrxracer
Sep 6, 2004 08:10 PM
fake mugen power
Jan 19, 2004 07:55 AM
