Where do I buy theses and how do I install them?!?
Old Mar 7, 2016 | 05:26 PM
R.Bush Mechanic's Avatar
Default Where do I buy theses and how do I install them?!?
I want fender guards on my del sol like this but can't find were to buy them or a diy page on installation. Any help would be awesome
Old Mar 7, 2016 | 05:40 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: Where do I buy theses and how do I install them?!?
I have been lookong for some for a few weeks now.
I can only find them here.
universal jdm flares | eBay
And looks like most are over seas with 1month shipping time.
I also havnt found and diy for them, but im guessing drilling holes on the fenders is needed.
Then use a bolt and a nut to secure them.
These are the ones im leaning towards buying when i do order some.
http://www.ebay.com/itm/universal-fe...VWufnJ&vxp=mtr
Might want to order some of this also, i am.
http://www.ebay.com/itm/Black-Car-Do...BSpWWw&vxp=mtr
It will help seal any gaps the flare/body with have.
Just put it on the top edge of the flare.
These also look good.
http://www.ebay.com/itm/2-JDM-Fender...dW2zg3&vxp=mtr
Old Mar 7, 2016 | 10:45 PM
won't that be prone to rust?
Old Mar 7, 2016 | 10:54 PM
Shit Posts: 15
10 Year Member
The hole drilling?
Yes it will if you dont primer the holes.
Without drilling into the fenders youll need to use some adhesive tape, the flares will fly off as soon as you get on the road.
Here are the steps i would do.
Mock up flares to fender/wheel arches and tape them in place.
Drill holes in the flares where they have the slots for holes, penetrating the Fenders/ wheel arches behind it.
Remove the flares/tape.
Mask around the drilled holes and spray primer inside the holes.
Remove masking tape.
Put flares back on car and use a bolt going through the front of the face of the flare and a nut on the inside of the fenders to secure them in place.
Use a washer on the bolt head side and the nut side.
If i do get some ill be sure to do a diy!
Old Mar 7, 2016 | 11:09 PM
b20hatchek's Avatar
I'll be waiting
Old Mar 8, 2016 | 12:58 PM
yeah a little clear coat should do the trick, ill see if i can find some universal fender flares.
Old Mar 8, 2016 | 01:46 PM
toyomatt84's Avatar
Sanji
Originally Posted by JDMswagSerf
The hole drilling?
Primer alone won't prevent rust. Its not a sealed coating. You'll need a clearcoat over it or some sort of sealer.
Old Mar 9, 2016 | 01:34 PM
thirty3's Avatar
I believe you need to cut / trim the fenders otherwise your widened wheels/tires are going to rub/hit the original fender unless you use narrow wheels that sit inside the original fender.
Old Mar 9, 2016 | 06:44 PM
Shit Posts: 15
10 Year Member
This is true if you want to lower the car with wider wheels.
If you just want the flare to cover the wide wheels and youre not currently rubbing, it will be fine.
If you put the flares on and narrow wheels so you wont rub it won't look good imo.
Old Mar 9, 2016 | 07:09 PM
im not a fan of the lowering thing if anything i wouldn't mind it being raised a inch if it means fitting bigger tires and flares more clearance is always nice on a car that is already hard to get into lol
Old Mar 9, 2016 | 07:49 PM
toyomatt84's Avatar
Sanji
Well, are you trying to improve handling characteristics? Because lowering the car (in moderation) will effectively improve your handling characteristics by lowering the center of gravity.
Old Mar 11, 2016 | 10:16 PM
king06's Avatar
Off topic, that thing is awd!!
Old Mar 13, 2016 | 09:36 PM
b20hatchek's Avatar
No, tha Sol has a turbo k swap rwd
HairyHarry
Jun 28, 2015 11:07 PM
JC_1118
Nov 23, 2012 07:48 PM
kobeballer96
Feb 17, 2009 07:09 PM
X-Psico
Jun 12, 2007 07:22 PM
wazuph2o
Audio / Security / Video
Mar 4, 2004 08:12 PM
