99 Integra LS no start
Old Mar 7, 2016 | 05:22 PM
shadedsky's Avatar
Default 99 Integra LS no start
Ok so I recently purchased a clean 99 Integra shell, and a b18b1 complete swap ECU and all. I have gotten everything together and after double checking all my grounds I went ahead and tried to start the car. I had all my dash lights come on, and the fuel pump primed telling me the main relay is good. However when I go to turn the engine over the starter won't engage. I can hear the clicking coming from the engine bay but it won't start. The dash lights do not even dim. However if I do apply a 12v power to the starters ground, the starter turns right over and starts the car no problem. I'm trying to diagnose the issue and I'm coming up short. Any help is much appreciated.
Old Mar 8, 2016 | 04:10 PM
tamboo's Avatar
10 Year Member
Default Re: 99 Integra LS no start
try cleaning the ignition switch contacts.
dont worry about the springs, see page 2:
DIY Ignition switch cleaning - Team Integra Forums - Team Integra
if that doesnt solve it then do this:
Rebuild your starter for less than $20 - Team Integra Forums - Team Integra
Old Mar 27, 2016 | 09:47 AM
trm4life's Avatar
Sounds to me like you need to clean up your battery to body ground. Also trickle charge your battery for a day or two to be sure u have a full charge. My problems have been battery rather than starter in the past.
qlcooper
Nov 24, 2012 07:00 AM
mr civicky
Apr 29, 2012 08:49 AM
91da_teg
May 14, 2009 05:56 AM
Arsenal
Aug 1, 2006 10:57 AM
nezr
Jan 18, 2005 01:01 AM
