EG GSR Swap no start
Old Mar 6, 2016 | 10:20 PM
cesarr's Avatar
Default EG GSR Swap no start
Hi I have 1994 Honda Civic CX with gsr swap and an intermittent no start problem.
I have checked all 3 fuses and grounds. I have tried swapping a known good main relay.
Any help, thanks.
Old Mar 6, 2016 | 10:23 PM
Former User's Avatar
Default Re: EG GSR Swap no start
Post the CEL codes.
What ECU?
Old Mar 6, 2016 | 10:25 PM
cesarr's Avatar
P72 ECU, check engine light stayed on. Will get codes next time problems occurs.
Old Mar 7, 2016 | 06:37 AM
averyvm's Avatar
If the check engine light stays on, chances are the ecu is NOT sending the ground signal to the PGM-FI main relay to prime the fuel pump.
Do you know how to use a Digital Multimeter?
Old Mar 7, 2016 | 06:44 AM
cesarr's Avatar
I kind of know how to use one
Old Mar 7, 2016 | 06:49 AM
Step 1 --> Reset ECU to clear codes.
Step 2 --> Crank engine for 30 seconds.
Step 3 --> Pull the CEL codes and post them.
Old Mar 9, 2016 | 10:26 AM
Mr_Norm79's Avatar
My recent GSR swap had a similar issue. My issue was bad grounds wires.
JdmJah
Engine Management and Tuning
Dec 7, 2012 02:13 AM
themex77
May 9, 2007 06:41 PM
BOOSTEDgreeneg
Sep 15, 2005 07:27 PM
01IntegraSE
Mar 20, 2003 05:56 PM
