2000 honda civic ex manual transmission - trouble with upstream oxygen sensor heater
I,m having trouble with my 2000 Honda civic ex manual transmission upstream oxygen sensor heater.Apparently I,m not getting the correct negative ground.It is causing a check engine light code.saying that I have a bad oxygen sensor heater.
Can you tell me What is the wire colors that goes to the computer so I can make a jumper wire from the computer to the ground wire on the upstream oxygen sensor heater?
joshuafr
Feb 8, 2012 07:56 AM
HondaGSX
Nov 29, 2005 03:58 PM
