Civic 99 b20z2/trany sir ecu problem
I hope you can help me im about to buy a 1999 b20z2 with sir trany or si im not sure and the only problem is the engine cut off around 3000rpm so i dont know what could make this if you can help me that could be nice also what is the best ecu to run with this swap thx
best ecu is a tuned ecu (hondata,neptune,crome).
other option is a p75 integra ls ecu. to do that you also really need a fuel pressure regulator to run about 10 more psi fuel.
it will not run well at all with the b16 ecu. is the check engine light on? does it light up when you put the key on then click off a second later? make sure it still has the bulb in it
So i got some news of the car ther is arledy a p75 ecu in so should i chip it and if yes what base map am i runig cause i dont see base map of b20 non vtec also what chip should i get
crookson speed
Feb 19, 2014 01:32 PM
