dry ice
Old Nov 6, 2002 | 07:37 PM
94hondaLS's Avatar
Default dry ice
what do you guy think about putting dry ice in my intake air box to condense the incoming air. as you know the cooler the air the more power you make. just a thought from a honda owner that wants more power. muhahahahahah
Old Nov 6, 2002 | 07:41 PM
tek_civic's Avatar
Default Re: dry ice (94hondaLS)
well it might work a little until the ice melts, and as long as it doesn't block too much air flow. for some more cheap power you could take some flexy hose, take out a headlight and run the hose right through where your headlight goes all the way to your throttle body, that should give ya some powa!
Old Nov 6, 2002 | 07:42 PM
SpoonFedHatch's Avatar
hahah try it if you wanna make .0000003 more hp
Old Nov 13, 2002 | 03:04 PM
MiraiZ's Avatar
remember...dry ice is frozen carbon dioxide...you car needs cold oxygen, so it may not make that big of a difference
Old Nov 13, 2002 | 03:24 PM
Archidictus's Avatar
Unceasing Measure
Default Re: dry ice (MiraiZ)
and all it takes is one piece getting sucked into your engine and you're hurting bad. if you want more power, take your stock airbox off and put a cheap K&N conical filter at the end of your intake manifold/throttle body. It's not an "intake" per se, but it'll get you down the 1320 faster.
Old Nov 13, 2002 | 03:37 PM
93hybrid's Avatar
Default Re: dry ice (Archidictus)
dry ice = filter/intake =
Old Nov 13, 2002 | 07:36 PM
Shreik's Avatar
i don't think it'll do any good. The reason colder air gives u "more power" is because it is denser therfore contains more atoms of oxygen. if u have the dry ice in your air box it will just cool the air inside the air box, but u still have the same number of atoms getting sucked in, they're just more packed together. anyway, as the dry ice (frozen CO2) evaporates it will take up the space of the oxygen and will probably do more harm than good.
correct me if i'm wrong about the "same number of atoms going to the engine"
Old Nov 13, 2002 | 08:06 PM
splitime's Avatar
you engine will choke, you'll be putting tons of CO2 in there, think what happens when you dont get any oxygen into your lungs......
Old Nov 13, 2002 | 08:10 PM
Kamin's Avatar
Default Re: dry ice (splitime)
im gonna go against the grain here (kinda)
say your at the track
between runs you can put a bag ofice on the intake manifold and it will get the IM really cold and that has a cooling effect on the incomming air
but remove the ice before you run
and it dosent do jack **** on the street.
Old Nov 13, 2002 | 08:32 PM
redcxhatch's Avatar
Default Re: dry ice (KAMiN)
Tons of ppl use ice on their im and engines at the track. Dont put it in your intake, but maybe on the inatke it could help out.
Old Nov 13, 2002 | 10:24 PM
Patron's Avatar
Default Re: dry ice (DMS Racing)
CO2! VERY VERY DIFFERENT FROM O2, I just love the uninformed and the ignorant when it comes to cars... go to school get an education....think! there's no easy way to make your car fast or look cool, it takes work!
Old Nov 14, 2002 | 12:01 AM
NrG's Avatar
NrG
Default Re: dry ice (ptran13)
hahahah, foo though just because the dry ice is cold, means it will cool the air?
blah, education is what you need.
Old Nov 14, 2002 | 01:43 AM
chillly's Avatar
CO2! VERY VERY DIFFERENT FROM O2, I just love the uninformed and the ignorant when it comes to cars... :
Hey *** clown, he's talking about experimenting with ways to make the temperature of the air entering his intake to become cooler. Cooler air is more dense. Denser air has more oxygen per square unit area. More oxygen produces more thorough combustion and results in increased thermal efficiency. Increased thermal effeciency results in more power.
Perhaps you're the one who needs to go to school and think. I applaud 94HondaLS for trying to come up with an innovative way to make more power, and the last thing this forum needs is unimformed ignorant ****-holsters like you spouting out bullshit when the reality of the matter is you don't have a ******* clue what you're talking about. I suggest you quit jacking your jimmy during Physics class and pay attention; you just might learn something yourself.
edit- where's BDC when you need him
[Modified by uncivilCivicinprogress, 5:44 AM 11/14/2002]
Old Nov 15, 2002 | 09:08 AM
Micro's Avatar
CO2 Displaces O2 and that is why it is used in Some Fire EXTINGUSHERS...
I think we covered that in HS Chemistry. Now what you could do is Place the Dry Ice one the OUTSIDE in an effort to Cool the Air inside. That would have been a More educated and informed Idea.
Thats what I was gonna say. The dry ice on the outside works considerably well with Forced induction on Air/Air intercoolers. With Air/Water with externals water pumps, you put regualr ice and water inside... ahh **** it, i'm tired of writing. you get the point
Old Nov 15, 2002 | 10:18 AM
BROOD's Avatar
Probably the most insightful bit of information in this thread.
As long as the dry ice is external of the intake air it can be used to cool engine components (intake manifolds, intercooler cores, etc.). But considering the extra handleing percautions over regular ice and extra cost.....it really isn't much of an improvment over using plain ice. And we haven't even gotten into the possible thermodynamic alterations that may be present with the much lower cooling temps that dry ice would offer. Sometimes too cool is not a good thing. Something to think about.
I've personally used bags of regular ice, N2O cooling systems, and compressed CO2 cooling systems to chill intercooler cores before. I leave the dry ice to keeping my steaks cold.
Trying new ideas is good......it feeds the brain you know.
[Modified by SLPR, 11:19 AM 11/15/2002]
Old Nov 15, 2002 | 11:37 AM
b18bomber's Avatar
Default Re: dry ice (uncivilCivicinprogress)
__________________________________________________ _____________
nice try dipshit, trying to use some mechanical/physics terms to wow the uninformed...wow you are a real genius, but why don't you go back and read his original statement.
Old Nov 15, 2002 | 11:50 AM
Hyjnx's Avatar
OH YEA! most def. i was at the track some months back and i saw a guy with HUGE packs of ice all over his engine trying to cool it down. Same thing with the NX N-tercooler..they spray NOS onto the intercooler to freeze or make the air alot colder thats comes into it...seems smart..but i wouldnt use it for street apts if ur gonna use the dry ice..just an inbetween run cooldown
Old Nov 15, 2002 | 12:18 PM
TheGreenBeast's Avatar
Default Re: dry ice
It's not worth the effort to freeze up the intake meanwhile the engine heats it back up almost immediately
Old Nov 15, 2002 | 12:47 PM
ViZ's Avatar
ViZ
you could make an airbox with a chamber that goes around it that you can put the dry ice in so that it cools the the area around the filter but i dont see getting any major gains from this
Old Nov 15, 2002 | 01:40 PM
Beave0101's Avatar
as mentioned, Dry Ice on the Intake Manfold,
Make a noticble difference? Probably Not
Much smarter idea? Hondata Intake Manifold Gasket
Old Nov 18, 2002 | 06:40 PM
chillly's Avatar
Default Re: dry ice (b18bomber)
OK, that was my fault; I didn't catch that he had said in his airbox as opposed to on his airbox.
Edit- I had to do something to something to liven up an otherwise dull morning
[Modified by uncivilCivicinprogress, 10:41 PM 11/18/2002]
Old Nov 18, 2002 | 08:01 PM
lsdhatch's Avatar
I don't know about gains in HP but I heard dry ice can be used to pop out dents is that true?
Old Nov 19, 2002 | 02:00 AM
Extent's Avatar
Default Re: dry ice (ridge racer 2)
I have to give the guy for the effort here. It's not that he has a total lack of understanding, he just dosent have a total and all encompasing understanding of how everthing works like all the rest of you, so rather than flaming him off the bat how about just educated responses? It's not like he came on here asking about NAWZZZzz or anything like that. Have an educated discucssion on the topic (or give the link to last weeks educated discussion on the topic if that's the case ) and they'll leave more educated than when they came in.
That being said, even if the airbox was chilled I dont know if that would really give you any real benifits. It's a big deal with boosted engines because the super/turbocharger heats up the air alot, but for a normal NA setup? I dont think it would
Old Nov 19, 2002 | 03:15 AM
kingpen's Avatar
Default Re: dry ice (Extent)
i know this is off topic, but i have heard if you put dry ice up to a dent it can pop i out......is this true.....and btw i have seen people put ice bags, but not dry ice.
Old Nov 19, 2002 | 04:34 AM
BROOD's Avatar
Default Re: dry ice (kingpen)
Yes it can work...not always though.
The extreame cold temp of the ice cools down the sheet metal quickly. When metals get colder their molecules move closer together and the material tends to "shrink-up" or contract. This contraction sometimes is enough to nudge the dent out of the sheet metal.
Another note to add to the dry ice being used to cool the inlet air:
Cooling the air box won't work as well as cooling the intake manifold. The air box (because of material, mass, and distance from the engine) will not be as efficient of a heat sink as the intake manifold. The (usually) cast aluminum intake manifold will have better heat transfer properties than the thermoplastic air box.
[Modified by SLPR, 5:37 AM 11/19/2002]
