Transmission & Drivetrain Gearboxes, Differentials, Clutches
Axle doesn't line up with mid shaft right
Old Mar 3, 2016 | 01:03 PM
lolv8s's Avatar
10 Year Member
Default Axle doesn't line up with mid shaft right
Ok I'm pretty sure I have a wrong part. Probably mid shaft because I ordered the axles from hasport and both inner sides of them are male. But the outer end of my mid shaft is male. So I have two male ends together. I have a S80 lsd trans.
Old Mar 3, 2016 | 09:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Axle doesn't line up with mid shaft right
What application are you using the axles in (year, body) and what did you order axles for (fit what) ???
Old Mar 3, 2016 | 11:05 PM
lolv8s's Avatar
10 Year Member
1996 Integra coupe, b18a1 built by me. DC4. They were titled " hasport chromoly axles 94 95 96 97 98 99 00 01 RA Integra B-series b16 b18"
Old Mar 4, 2016 | 10:44 AM
Hasport's Avatar
who did you buy the axles from? and do you have a picture of both axles?
Old Mar 4, 2016 | 05:25 PM
lolv8s's Avatar
10 Year Member
Hasport from from eBay. And this is the best pic I have of them right now. They are currently in my integra it's just that the driver side one isn't able to connect. I've done some browsing on eBay and I've seen that the DA Integra's half shaft has a female end and not like the one I have. Do you think this could solve my problems? Or am I taking a risk? I'm aiming for 500hp. I'm thinking I could have ordered the wrong axles. But they are typed right.
Old Mar 6, 2016 | 02:03 PM
lolv8s's Avatar
10 Year Member
Bump
Old Mar 6, 2016 | 09:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
All '94-01 Integra axles include a female inner joint on the driver's side axle... meeting the midshaft that you have pictured. The '90-93 Integra axles both have male inner joints... a half-splined one for the right side and a full-splined one for the left side, which meets the female socketed midshaft. You received the wrong axles needed for your application and midshaft.
Old Mar 7, 2016 | 09:08 AM
Hasport's Avatar
you can send the driver side axle back to us and we will fix it for you to work in your application
do you remember by chance what the part number was on the box when you received it?
Old Mar 8, 2016 | 05:34 AM
lolv8s's Avatar
10 Year Member
Thanks a lot man. Turns out I've had the axles wrong side of the car. Been building this car since I was 16 now I'm 20.... Learned a lot of stuff so far and axle placement included. Pulled them out because I knew there was a chance of them being backwards or they needed to be replaced. Turns out to be my fault. Thanks again.
Old Mar 8, 2016 | 05:35 AM
lolv8s's Avatar
10 Year Member
Sorry for the inconvenience I've had the axles on the wrong side of the car. But thank you anyways.
pnwjdm
Dec 23, 2012 08:57 PM
crex23
Oct 1, 2005 12:42 PM
crex23
Sep 29, 2005 08:34 AM
90hbvtec
Dec 11, 2003 06:08 PM
McDade
Sep 1, 2003 07:49 AM
