Honda CR-V & Element 2WD & 4WD Element & CR-V
Replacing front RH strut
Old Mar 1, 2016 | 09:16 PM
accerat's Avatar
Default Replacing front RH strut
Hey guys, 2002 Honda CR-V 5 Door EX (4WD) KA 5MT.
I'm looking for a strut assembly to replace a bent one. I've found two struts on ebay:
Suspension Strut and Coil Spring Assembly Front Right Fits 02 06 Honda CR V | eBay
and
02 06 Honda CRV Front Complete Struts Shocks Coil Springs w Mounts Pair X2 | eBay
The problem is, would these work on mine? My car is a stickshift not an automatic and on hondaparts the frontassembly for a manual is
51601-S9A-A16 and for an automatic is 51602-S9A-A06. The strut itself is similar but i think the spring is different. Should I be worried about that? Do you know where else could I get a cheap set?
Old Mar 2, 2016 | 02:01 PM
LDForget's Avatar
Default Re: Replacing front RH strut
id cross refrence the part numbers individually and see whats different. i would doubt itd be much.
Old Mar 2, 2016 | 08:40 PM
accerat's Avatar
The biggest difference is the spring itself
51401-S9A-903 and 51401-S9A-024
but i don't know if that matters
Old Mar 3, 2016 | 02:17 AM
LDForget's Avatar
likely a slight spring rate difference. the automatic transmission is heavier than the automatic. if youre changing 1, change them both, as youre supposed to. I cant see the difference between automatic and manual being much. If you look in the aftermarket, they likely use "automatic" spring rates for both manual and automatic. I havent looked, but thats my educated guess.
b18punk
Jul 12, 2004 04:27 PM
redciviclx14
23
Jul 18, 2003 04:18 PM
RCautoworks
55
Apr 24, 2003 04:53 PM
daniel89civ
Feb 9, 2002 02:36 PM
