Jdm d15b vtec obd2 with d16z6 head - rebuild kit for turbo?
I got a Jdm d15b vtec with a d16z6 head single solenoid vtec, 4 wire O2 sensor an p2p ecu. What rebuild kit do I need? An I would like to turbo it eventually. Any help here please?
what exactly are you trying to rebuild? entire engine? head?
you say you will want to turbo it later what will your power goal be?
The entire engine an the head. I know there is not a kit for it. I have to order the stuff separate but I need to know what I'll need to get. I can't find the information anywhere for what all I need. An I'm looking for about 300 to 350 hp
If you're rebuilding everything then send the motor out to a machine shop. Valve job, hot tank block, magnaflux, port and polish head are all good ideas. Better rods and pistons, oem valves. Basic stuff like head gasket and seals idk what you need to know.
tgordenDELSOL
Sep 24, 2014 01:15 PM
WhiteyW/AHonda
Sep 11, 2011 04:49 PM
