FL Crx Swapped with COLD Ac $2500
Old Mar 1, 2016 | 09:01 AM
DONTSLEEP_'s Avatar
Default Crx Swapped with COLD Ac $2500
89 Honda Crx dx
97 B20b
Gsr throttle body
Edelbrock Pro-Flo Fuel Rail
Aeromotive A1000 Fuel Pressure Regulator
B&m Fuel Pressure Gauge mounted to fuel filter
Steel braided fuel line from filter to rail/fpr and down to return
Greddy 4-2-1 one piece header
Tanabe Medalion Exhaust
Steel ef B-Series swap mounts
Innovative Mounts Ac Mount
obd0 to Obd1 Jumper harness was also used to do dual point to multi point swap
obd0 to obd1 disturber jumper
Cable Ls transmission (occasionally pops outta second and grinds high thrid)
Fidanza 8lb Flywheel
Stock clutch and pressure plate :-/
Omni Power Full coilover
Front Skunk2 camber kit
Steel braided brake lines front and rear
Rear No Name Red Lower Control Arms
Rear Disk Brake Conversion
PERSONAL GRINTA Steering Wheel Black Leather w/Red Stitch
Nrg quick release steering hub
Black ap1 Leather seats on Crx Rails
Clean black cargo covers
90-91 Tail Lights
Cons
Broken Ac control (not to the naked eye) still works and function just can't switch from cold ac/heat.
On steelies (roll arounds) Needs 2 tires
Leaking front caliper (can't remember which side)
Car was recently vandalized and now has a dent in quarter panel as for the Price drop $2,500 Firm Lowered for quick sale!
Car is Located in Lakeland, Fl.
813.667.6810
Old Mar 3, 2016 | 12:43 PM
Jack Kun Aguero's Avatar
Default Re: Crx Swapped with COLD Ac $2500
Old Mar 4, 2016 | 06:58 AM
DONTSLEEP_'s Avatar
Originally Posted by Jack Kun Aguero
Give me a call.
DONTSLEEP_
Jan 10, 2016 12:09 PM
btd
Aug 15, 2011 03:26 PM
Layziejoe775
Jan 28, 2008 08:52 AM
Layziejoe775
Aug 15, 2007 11:21 PM
Dialectic
Jun 4, 2006 04:54 PM
