1995 EG Civic R18 Swap
Old Feb 27, 2016 | 06:27 PM
rpm systems's Avatar
Default 1995 EG Civic R18 Swap
Thought you guys might get a kick out of the R18 swap into a Eg chassis.
Old Feb 28, 2016 | 10:04 AM
vtecnique69's Avatar
Default Re: 1995 EG Civic R18 Swap
its definitely different. was there cost savings over a k24 motor? the r18 isn't generally a performance motor so im a little lost on the reason for this build (was the owner tired of all the cookie-cutter civics on the road?)
Old Feb 28, 2016 | 03:27 PM
Correct about the cookie -cutter stuff . I am into doing different things with these Honda engines . It allowed me to also learn all the in's and out's of the wiring and overall engine . when taking the car out for its first real drive , I was impressed that the throttle response had no delay. Now mind you we have not used any type of tuning devices yet . so the power that we felt was all from the stock tune . Price over all was cheaper than doing a K swap . R18 axles where compatible with the EG . The mounts is a mixture of Hasport mounts that they sell . As Hasport does not yet make a kit . Wiring is the same as the DBW k20Z engines . which I solved a few years ago . Even the shifter we got off another Honda that worked perfect. All other parts where off the shelf parts you could get at your local autopart store or Ebay. Once it comes back from Paint . We plain to dyno the car before and after the reflash to get you the pros and cons of the swaps power . Once that all happens . this fall we plain to boost the car . As there is nothing hard about bolting a kit up at this point .
Old Feb 28, 2016 | 03:40 PM
NotARaCist's Avatar
I never narc'd on nobody!
Huh, well that's...different. Seems like a lot of work for the 138 stock BHP, though. Whatever strokes your kitten I guess Still though, props for pulling it off.
Old Feb 28, 2016 | 04:37 PM
but those number come from being in a stock car . which weights 33-3500 pounds. now in a car that weighs in at 2251. that is a difference. so the 138 hp that you are quoting . is not correct for this setup.
Old Feb 28, 2016 | 04:42 PM
NotARaCist's Avatar
...I'm just going to let you think about what you just wrote before I lay into you. I'll give you a few minutes to realize how bad you just fucked up.
Old Feb 28, 2016 | 05:28 PM
power to the wheel and power to the crank are two different things . so when the engine is dyno in a car that is 3000 lbs . then same engine is put in a a car which weights 1500 lbs . the engine is power to weight is not going to change on the dyno . so mass of a object will not change the factors of acceleration then is what you are telling me ? well all the laws of physics are then out the window then. but you have the right to say what you like . that is fine by me .
Old Feb 28, 2016 | 05:30 PM
hondur's Avatar
Dur Da Dur
5 Year Member
You should get a header for the car!
Old Feb 28, 2016 | 05:52 PM
tony_2018's Avatar
Fish Twig
If these are the same guys who specialize in j swaps I'm sure they know their **** and this was probably a customer request and just wanted to share their work.
Old Feb 28, 2016 | 06:08 PM
hondur's Avatar
Dur Da Dur
5 Year Member
@tony_2018
Is this a header?
Old Feb 28, 2016 | 06:18 PM
NotARaCist's Avatar
Oh boy, this again. And tony, if they actually think that horsepower is dependant on chassis weight, then they could be the masters of swapping jet engines into Civics,
Old Feb 28, 2016 | 07:42 PM
eghatch9295's Avatar
Stancetard Hate Monger
what in the **** is going on in here? 138hp is somehow more in a lighter car? like the motor is spinning the car on a dyno? WTF?!
Old Feb 28, 2016 | 08:10 PM
NotARaCist's Avatar
According to this "professional", apparently
Old Feb 28, 2016 | 08:33 PM
hondur's Avatar
Dur Da Dur
5 Year Member
He's probably tired or drunk, leave the guy alone. I doubt it'l be a constant thing like cough you know who cough cough. On the other hand, i really really want an answer from @tony_2018
Old Feb 29, 2016 | 04:07 AM
tony_2018's Avatar
Fish Twig
Originally Posted by hondur
@tony_2018
Is this a header?
LOL, hense my signature from a previous member
Old Feb 29, 2016 | 04:09 AM
tony_2018's Avatar
Fish Twig
Oh right, didnt' catch that. I don't think so.
Old Feb 29, 2016 | 04:18 AM
tony_2018's Avatar
Fish Twig
TBH, to me I still consider it as a header. Exhaust gas still exits out that port. Could be a down pipe as well.
Old Feb 29, 2016 | 05:11 AM
hondur's Avatar
Dur Da Dur
5 Year Member
They're sold as PreCatDeletes
Old Feb 29, 2016 | 06:07 AM
tony_2018's Avatar
Fish Twig
Whatever you want to call them.
Old Mar 1, 2016 | 09:49 AM
kp's Avatar
kp
This is a very convoluted comment, but I think I follow.
Wheel HP and Crank HP are two different things, you're right.
Your comment starts to get fuzzy when you compare different weight cars on a dyno. Let's be clear here, the vehicles weight has zero effect on dyno results. You'll get 138hp regardless of the vehicle.
But then you get into talking about power to weight, this is an entirely different thing. Power to weight is the ratio of weight:horsepower. For instance, putting an R18 into a go-kart would be fiercely fast, because the go-kart is very light and the engine would propel it effortlessly (probably around 0.3hp per pound). However, put that same R18 into a full-size SUV and you'd be lucky to pull away from a stop sign (around 0.02hp per pound). This is power-to-weight in action.
Your R18 EG would certainly be of better power:weight than the original heavier Civic it came in, this is obvious.
But the horsepower does not change.
Old Mar 1, 2016 | 10:01 AM
king06's Avatar
I'm sure power to weight ratio is what he means. Cool and interesting swap.
Old Mar 4, 2016 | 10:01 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Just cleaned up the thread a bit. Folks, it is possible to debate and/or educate without being abusive. Kp's post above is a good example.
Old Dec 5, 2018 | 06:34 AM
Ballestrini's Avatar
Hello friend, im from Brazil and i bought a R20 with 6 MT transmission for swap in a Civic EG, can you help with the mounts models or photos ?
I think is the biggest difficult that me and my friends found on this swap, we have a 6 EG group doing the same swap.
what power steering pump are you using ?
thank you, and congratulations for inovvation.
Old Jul 30, 2019 | 12:48 PM
Chuppy_2o3's Avatar
What motor mounts did you use I’m doingsame exact project
Old Jan 11, 2020 | 10:22 AM
di zazzo's Avatar
Beleza cara?
Tenho um Civic 2000 LX e meu D16 foi para o espaço e estou pensando em fazer a mesma coisa, o seu já está pronto?
Como a base deles é parecida, acho que és soluções podem ser as mesmas, você documentou e pode dar algumas dicas?
Valeu.
Eg9502
Sep 7, 2014 11:30 PM
T-78RX7
Dec 29, 2008 08:29 PM
hondastreet
Mar 5, 2008 12:36 PM
civic eg k20
Nov 20, 2007 01:54 PM
