Constant tapping in engine - Modded 93 EG Honda Civic
So,
put a B20 turbed engine in her (B16 head),
as soon as we got the car all wired up & everything done 2 run etc there has been a constant tapping noise since.
She's been running for about 2 months now.
The tapping/ticking is loud, u can hear it from inside & outside of the car.
It taps when we first turn it on, while it's idling, accelerating etc etc.
We were told it was the valve clearance but we done all that to perfection & it's still tapping annoyingly what else can it b? Not gonna take it to a mechanic yet coz I'm not paying $80+ for them to tell me it could b this or it could b that then charge more to actually fix it, rather just do it ourselves.
Any ideas?
Bare in mind she isn't tuned yet nor is there a front/top mount on her & also no BOV.
Any tips would b hugely appreciated
Any ideas?
Valve clearance needs to be set with the engine cold.
Side note: If you are running that setup without a tune you are an idiot. But if you don't give a **** about the engine blowing up, then by all means, please continue.
^That.
don't drive it untuned. you are pushing a **** ton more air into your motor and not adding anymore fuel. This leans out the motor and cause a lot of problems, usually ruining your build. I'm surprised it is still running after 2 months to be honest.
What is a front/top mount? some sort of hybrid? lol
...No intercooler, no tune, no blowoff, running for 2 months, and you wonder why your motor is fucked? Yes, your motor is fucked. You fucked your motor.
^That.
Front/top because we haven't decided which mount we're gonna go with
It's painfully clear that you have no idea what you're talking about. Given that, it's a safe bet that you didn't do valve lash properly, if at all. Did you open the motor at any point? What's your P2W? Exactly what did you set your valve lash to? Exactly how did you do it? Convince us that you aren't as dumb as you are, quite frankly, making yourself look.
I've heard 2 diff sides to whether driving while untuned is okay enough or not & both sides seem legit so I guess we'll just have to take our chances coz apparently it's not as bad if u don't hit boost which we don't nornally do at this stage.
I didn't post to get the **** ripped outta me lol just wanting some genuine feedback
You're getting genuine feedback. If you think driving without a tune is a good idea, you are being stupid. If you listen to someone telling you to drive without a tune, you are listening to an absolute ******* moron. You also completely avoided actually answering any of my questions. Do you want help, or do you just want to play the game of confirmation bias?
If your boyfriend is the one doing the work, maybe we should be talking to him. You still have chosen to ignore some very simple questions I have asked. And just to be clear, driving without a tune is pants on head retarded.
Did you ever think that maybe you aren't getting the pretty welcoming committee you were expecting because you aren't playing ball with us? I have asked you five simple questions. I have pointed you towards those questions three (now four) times. you have refused to even try to answer four of them, and made an excuse for the fifth. That's not how things work around here. If you want help, you have to answer questions. If you cannot answer questions, get your boyfriend in here and have him ask for help - middle man threads never end well, especially when the middle man quite clearly doesn't know what he or she is talking about. If you won't answer simple questions, then quite frankly, it doesn't matter who is telling you anything.
Now, I am going to ask you one last time. I am going to number these questions, and I am going to give them each their own line, so that there is absolutely no chance that you can miss them all. I'm even going to combine two into one, just to make things easier for you. If you do not know the answer, then do not post. Get your boyfriend to answer the question.
1: Exactly what valve lash specs were used?
2: Exactly how was valve lash set?
3: Was the motor opened up at any point?
4: Exactly what is your P2W?
can u please be specific ? wt damage can it do? without being rude tho just trying to get some help dont need the names thanks
i havent taken it over 4000rpm and its not fukd it had the sound when it first startd up . i have advance the fuel so its not leaning out but its def getting to much air and yes i no ineed bov mount and am doing this week. but all i wontd to no is what else the sound culd be
umm i did answer once again ..... vavle lash set at 0.007" IN and 0.008" EX, i bought the motor and everything was new e,g gaskets waterpump cam kit bla bla so the head would ov came off , then wheni got it running was making that sound so done valve lash, and i put #1 piston tdc, loosend locknut adjusted as needed to specs and then #3 piston tdc adjust then 2 and 1 . and what is p2w?
P2W. Piston to Wall clearance. Too big a P2W can cause piston slap, which can also sound like a constant tapping. Since you bought the engine overhauled, I'm going to guess you don't actually know what the P2W is for your engine. Do you even know if the seller honed the block, or re-ringed the pistons? So, was this motor ever running, in your possession, without ticking? In your process of doing valve lash, did you check after tightening, or did you just tighten it down and say good enough? Did you check after giving the engine a heat cycle?
sounds a lot like a knock. narc is right, boost+ not even a half assed fmu hack, let alone a tune is drool on chin, laughing at your own reflection, shiny thing loving, fetal alcohol syndrome retarded. you're very obviously in over your head with this, so ill ask- whens the partout?
