PLEASE HELP!!! 95 civic lx bad rear tire wear
Old Feb 24, 2016 | 08:30 PM
DryFartWetDog's Avatar
Default PLEASE HELP!!! 95 civic lx bad rear tire wear
Ok so i could really use some help with my car. I have a 95 civic lx thats completely stock NOT LOWERED. Im having really really bad tire wear on the inside rear tires. Front tires are fine. I rotate them every 6k miles and 2 of a brand new set of michelen defenders are down to the steel thread with the outside of the tires at about 80% tread.
So obviously theres an alignment problem right? Well the tire place says they cant align my rear tires causing all this wear because it doesnt have a camber kit? Im reading online and seeing alot of you dont need camber kits etc then seeing something about a "shim" and also just adjusting the tow.
My big question here is there a way of avoiding having to buy a camber kit for the rear? And not doing some freaking jerry rig crap? Any help would be appreciated!
Old Feb 24, 2016 | 08:33 PM
red96turbols's Avatar
Default Re: PLEASE HELP!!! 95 civic lx bad rear tire wear
Alignment specs would be nice. Go back and ask for a run out; most shops do this for free. Post those, it'll help weed out the advisors against Camber kits that don't even know what your current specs are.
Old Feb 24, 2016 | 10:18 PM
eghatch9295's Avatar
Stancetard Hate Monger
worn rta bushings
Old Feb 25, 2016 | 04:28 AM
What's an RTA? Are you referring to the compensator arms?
Old Feb 25, 2016 | 07:08 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Rear trailing arm.
eH.
Old Feb 25, 2016 | 07:21 AM
I just noticed an uppercontrol arm in the rear is shot. Should i just buy new adjustable ones? I thought about just replacing the bushings but itll cost me less to just buy new ones and install them myself. Also i plan on lowering the car later down the road
Old Feb 25, 2016 | 07:46 AM
I like my adjustable camber arms because I track this car; even before then though I had them to have it at factory spec. camber will cause tire wear but not as dramatic as the toe angle. check those trailing arm bushings egH mentioned, our cars are old and rubber doesn't last for ever. it would benefit you to replace everything and align once than to do it sections and re align multiple times.
Originally Posted by eHMxhACk
Rear trailing arm.
eH.
ah, those are fun to do. I only asked as a lot of people refer to the compensator arms as rear toe adjusters (rta) just wanted clarification for the op.
Old Feb 25, 2016 | 08:43 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Originally Posted by eghatch9295
worn rta bushings
That is what I was thinking! Is there a nice DIY thread in here for this job? I heard they are a bear...
Old Feb 25, 2016 | 11:11 AM
https://honda-tech.com/suspension-br...mugen-1589298/
Old Feb 29, 2016 | 08:29 PM
Ok so tomorrow im installing the adjustable upper control arms for the rear and while im at it im going to take a look at these rtas you guys are talking about. My next question is how do you guys feel about lower control arms? Should i bother replacing the stock ones? I have the money to do it. Also should i align the car before or after the lcas?
Old Feb 29, 2016 | 09:26 PM
you should replace the bushings in your stock ones.
Old Feb 29, 2016 | 10:42 PM
Do they need to be pressed in? All the shops around me charge a pretty steep price to press them in. Can i rent a tool or use a c clamp with some wood blocks?
Old Feb 29, 2016 | 11:07 PM
pretty hard to do without a press, but possible. search on here, multiple threads. the reason to stay oem is bushing life. the aftermarket ones just don't last.
Old Mar 4, 2016 | 01:51 PM
Premium Member
Loved
Community Favorite
Nice, thank you!
circapunk
Mar 20, 2009 04:59 PM
EM2 Charlay
Honda Civic (2001 - 2005)
Dec 12, 2007 02:55 PM
alex_s817
Mar 25, 2006 09:43 AM
BigZ88
13
May 19, 2004 10:41 AM
The_PissingDog_Crx
Apr 5, 2003 09:54 AM
