A/T dpfi to obd1 A/T mpfi wagon swap,
hi guys,
i need some help with a A/T dpfi to obd1 mpfi wagon swap,
so i cut and soldered all the obd0 ecu wires to obd1 connectors. and im left with 4 wires
A8 - yellow (A/T relaterd) lockup solenoid??
B5 - white/yellow ALT C??
B7 - green/orange (A/T related) shift position console switch P / N??
B11 - green/black (A/T related) shift position console switch D??
thanks!
thanks!
Needs to be About 20% Cooler
the AT inputs (D N P etc) are to tell the computer that your in or not in drive mode so it can maintain idle speed etc. it wont flash the D4 light. all A/T codes are check engine lights on OBD0/1
of course if you hadn't of already cut the wire i would say go with a PS9 (=A/T PM6) obd0 ecu. MPFI, chippable, and plug n play.
there is also a wht/red wire that goes to the interlock box. i think it A8on OBD0. it's so you cant rev the engine past idle and throw it into D.
don forget you also need to add a heated O2 too.
historic4thewin
May 30, 2019 04:10 PM
sleeper_status
Dec 1, 2010 05:42 PM
