1999 Honda Accord crank, but won't start
Old Feb 21, 2016 | 09:11 PM
Tulga's Avatar
Icon5 1999 Honda Accord crank, but won't start
Hello, I have 1999 Honda Accord V6, and a few weeks ago, I parked my car, and it was on, but suddenly turned off, and never turned on again. It cranks when I try to start the car. I thought it might be the fuel pump, and changed it, but it was not, and I checked the spark plugs and ignition coil, there was no fire. Has anyone had the same problem?
Old Feb 22, 2016 | 12:05 PM
BlackLX4's Avatar
Default Re: 1999 Honda Accord crank, but won't start
Any codes?
Old Feb 22, 2016 | 12:26 PM
Tulga's Avatar
there was p0420 and p0440 or p0442 I can't remember which one was it but that says EVAP system leaking some like that. so those 2 codes were there before it happened. I just put some injector cleaner in to my tank, and the code p0420 goes away
Old Feb 22, 2016 | 05:55 PM
user456101's Avatar
Scotty Kilmer, a famous mechanic on YouTube has a video "Fixing a car that cranks but doesn't start up"
Old Feb 22, 2016 | 07:47 PM
tim73's Avatar
If you have(and are sure) you have spark and fuel, then it sounds like timing and or no compression. Did you slip and or break a timing belt?
SentinelK151
Aug 6, 2017 08:42 AM
Howard38
Jan 2, 2015 04:05 AM
jooanyenna
Jan 5, 2014 10:27 PM
EF927
Jan 25, 2010 03:54 PM
triple_b
Oct 6, 2005 05:55 PM
