JRSC Belt X-Reference #'s
Does anyone know what the cross referenced part numbers for the belts for a
'00 SI standard JRSC kit are? I dont want to spend $100 (exaggeration) and wait for a week for the belts. Plus I dont want to have to talk to any of the jerks there either ( big time a-holes ). If anyone can come up with these belt numbers I would appreciate it. THANK YOU!!!!!
Keith @ JR should be able to tell you on the fly...4PK800 is the crank--->alt, and 4PK620 for the SC belt.
Thats for a GSR though.
Sonny should know...where you at Sonny?
Its bando and good luck finding that belt ANYWARE except form JR, i even called Bando directly to find a reseller of that belt and they had none
Order a few just to keep in your own personal stock seeing how they get replaced every 10K miles.
BTW they only cost like $27 dollars shipped
Try this place. http://www.jdv-belts.com/anlcatig.html for the base kit you need the 4pk610. I needed the 4pk590 (10 lb) and the 4pk800. They quoted $18 for both!
[Modified by NuSiEr, 8:00 AM 11/8/2002]
JDMBOLONI
Nov 13, 2004 10:41 AM
