OEM Fog Light wiring/harnessing
Hey folks,
I have an 06 Accord, and could use a little help finding the right wire to tap into using a a coupler. I bought Spyder fog lights and have since ran the wiring under the driver side dash. I have my ACC wire attached, but can't seem to find a good wire to couple my innition switch wire to (green wire).
Would anyone be able to tell me which wire I can link it to, as this in my last step before testing my fog lights?
Any help would be greatly appreciated!!
Pics added, if someone could point out the correct wire or manner in which they accomplished this task, that is now going on day 2.
I hate wiring
First, can I ask how you plan to "trigger" the lights? By trigger I mean is it power (12v) that will make them come on of is it a ground that will make them come on?
Then, do you want them to only come on when the key is turned to "X" - or on at anytime.
Are you putting in some "switch" that will control the fogs - if so is that switch tied to a relay of some sorts?
Trim level (trim, doors) and engine might come into play so knowing that might help.
There are many ways to wire in aftermarket fogs so I'm just trying to understand the plan......I know the title said "OEM" but then you state the brand is an aftermarket. A true OEM or Dealer Kit is ~$235 and comes with everything you need.
crazyhorse2011
Aug 3, 2016 05:52 AM
Loserkidwac
Jun 4, 2007 08:44 AM
ukkb920
Mar 15, 2004 08:09 PM
