Stumped with brake issue 96 accord
Old Feb 21, 2016 | 06:36 AM
04compg's Avatar
Default Stumped with brake issue 96 accord
I bought this 96 accord yesterday, the guy couldn't figure out what was wrong with the brakes. He has replaced both calipers,pads and rotors. The issue is as soon as I hit the brakes both of them stick hard! Also noticed the pedal gets stiff when this happens too, I seen that he didn't replace the hoses but didn't think both would fail at the same time, what should I start looking into?
Old Feb 21, 2016 | 07:52 AM
sbrambo's Avatar
Default Re: Stumped with brake issue 96 accord
I wonder if it has something to do with the master cylinder not springing back to the normal position.
Old Feb 21, 2016 | 08:34 AM
hometheaterman's Avatar
Do they stick even after you let off of the brake? Inspect the calibers (they may have an issue). If not, I'd try bleeding them. If that still doesn't help I'd start looking at the master cylinder.
Old Feb 21, 2016 | 03:31 PM
04compg's Avatar
No they only stick when I push the brake, haha kidding yes they still stick when I let off the brakes, I'll try and bleed them again and see if there is air in system, pedal is very hard though so I don't think there is, I may try new hoses and see what that does
Old Feb 22, 2016 | 12:23 AM
holmesnmanny's Avatar
At first I would think it could be a rubber brake hose that has collapses internally and is acting like a check valve. Are you sure that both calipers are locking up ? Or are you saying the pedal is locking up ? Did you check the brake pedal linkage ? You might want to check the rear drum brakes to see if anything is going on back there that is holding the pedal.
94vtecmn
Jul 17, 2013 05:22 AM
RobertDJ
Jun 15, 2011 12:58 PM
dahliablue
Mar 24, 2010 09:12 PM
tlmg21700
Aug 13, 2008 06:25 PM
mkalisky
May 12, 2006 01:47 PM
