1994 Civic RTSi DOHC ZC Overheating question, lower rad hose cool, no heat in cabin
Hi Everyone,
I have a Japanese market 4WD 1994 Civic RTSi with the DOHC ZC motor. I am resurrecting the car here in New Zealand and I've run in to an overheating issue:
Symptoms:
Lower rad hose remains cool
No heat in cabin
Cooling fan won't turn on
Overheats at idle
Troubleshooting done:
All bleeding done according to service manual
All hoses checked for blockages, none found
System flushed
Thermostat replaced, tested and working before install, old one didn't close completely
Fan thermoswitch tested and working
Fan relay works
Fan works when jumped
Heater core bypassed, no difference
Near-new good condition rad
Things to know:
New Zealanders are terrible for using straight water for cooling, so I assume this was used for most of its life
Unknown age/condition of water pump, but timing belt looks really fresh, so it was possibly changed at the same time as this (unknown though...)
Engine was removed from a vehicle that was in a minor wreck (damaged roof) but may have been sitting for a couple of years
New oil put in recently, no contamination found in old oil nor when checking new oil
Am beginning to suspect a bad water pump ... but wondering if there's other things I've missed to diagnose the problem. Any way to test the water pump without removing it first?
Re: 1994 Civic RTSi DOHC ZC Overheating question, lower rad hose cool, no heat in cab
Originally Posted by deschlong
Right... So I should add, system was flushed. And I stated the thermostat was replaced already.
Pump impeller may have separated from shaft??
probably..or corroded. Heater core is probably clogged to *****. What you can do is disconnect the heater hoses from the engine and run a hose through it to verify proper flow. Connect the water hose to both inlet and outlet to verify if any build up comes out.
These guys are terrible for it here. Coming from a cold climate, I was dumbfounded. They even have watering cans at petrol stations so you can "top up" your rad. Crazy.
That's pretty astounding. At least you get all the cool vehicles, though. Hopefully replacing that water pump solves your problems.
When you get a chance, take a look at the heater core. I know its a bitch to get to but I don't want you having any overheating issues if fluid isn't flowing properly.
Thankfully the motor is not the original from the car. It is a replacement one I pulled myself from a wrecker yard JDM EG5. So the rust and **** collected in that other poor bugger's car which has now firmly departed this life and entered Honda heaven.
