96 Ex A/C clutch won't engage.
Hi all,
My a/c went out a few months ago and now that summer is starting already in Texas I figure it's time to fix it. I think it's a ECU issue but what do you guys think.
First thing first, I followed the instructions in the helms manual and also the Honda service manual and everything passes, yet my a/c clutch will not engag. I can jump the relay then it engages so it's not a clutch issue. But to be safe I replaced it anyway since I have a lifetime warranty on it. Along with the drier/expansion valve/ evaporator but still not working.
I checked every wire in the a/c and didn't find any breaks. I read a thread on here that I should be getting about 5v from number c5 wire on the ECU? I'm only getting about .3v. I've also noticed that when I select my A/C button on, that my engine RPM does not increase. Could it be that my ECU doesn't know the button is pushed in to increase the rpm and give those 5v out of c5? I looked up the wiring diagram and can't find the wire that sends true signal to increase the rpm when the A/C button is selected. I ordered a ECU from eBay and should arrive in a few days.
Any idea?? Thanks!
Any idea?? Thanks!
Also, you didn't mention whether the condenser fan runs when you press the A/C button..
Yes the condenser fan turns on when the a/c button is pressed. Also with connector A still plugged in I am getting battery voltage at 17. Does it have to be unplugged? That red/black wire runs to the pressure switch which I am getting battery voltage on the other side of the switch.
A Blu/Red wire runs between the pressure switch and ECU pin C5.
A Blk/Red wire runs between the clutch relay and ECU pin A17.
If I ground pin A17 the clutch does engage. And I rechecked the voltage on the blu/red connector of the pressure switch and I'm only getting .18v or (.05v with connector A unplugged from the ECU)
Unplug the pressure switch and ECU connector C.
With key OFF, test the Blu/Red wire for continuity and for continuity to body ground.
I checked the blue/red wire from the pressure switch to the C5 connector and it shows continuity. How do I check it for continuity to the ground? According to the diagram it's not grounded anywhere?
Touch one meter probe to pin C5 in the ECU connector and the other probe to the metal frame under the dash.
SpeedingHatch
May 22, 2006 09:58 PM
