SOMEONE HELP d16z6 swap....
Old Feb 20, 2016 | 09:49 PM
Caylen Klassen's Avatar
Default SOMEONE HELP d16z6 swap....
Okay all you Honda guys I need some help here;
I just put a d16z6 into my 91 Honda civic si
I'm getting a spark to the distributor but the fuel injectors aren't turning on.
Could this be the culprit? Its the plugs that go into the shock tower....please if someone can help me figure this out....ill be eternally indebted....this (easiest) Honda swap is making me want to drive off a cliff..
heres the two plugs that don't match up
someone said they are the old dizzy connections but Id just like a second opinion.
Old Feb 21, 2016 | 12:48 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: SOMEONE HELP d16z6 swap....
That's not even on the same side as the distributor. Looks like the portion that leads into the car for the under dash fuse panel. My question is if you're the one that just did the swap why did you disconnect that at all and/or why haven't you just reconnected? Aside from that I'd ask which injectors are you using?
Old Feb 21, 2016 | 04:52 PM
4drEF's Avatar
Keyboard Humorist
How did you manage to get a different firewall plug?
By the way it looks, you have a DX chassis and an Si engine harness.
JDM'd
Jun 30, 2010 11:54 AM
EF_yo_89
Jul 6, 2004 12:23 PM
