vtec solenoid help
Old Feb 20, 2016 | 11:56 AM
ninjs's Avatar
Default vtec solenoid help
Engine light came on auto zone diagnosed as engine variable timing electronic lifter control solenoid. Does this have to be changed or are there other things to do first do maybe you don't have to spend so much replacing? Just bought it and really can't afford more. He car seems to run great but am afraid to keep driving. 2001 accord with 2.3 VTEC engine.any help is greatly appreciated maybe my husband can fix it with a little help from someone! Thanks in advance.
Old Feb 21, 2016 | 02:40 AM
poorman212's Avatar
Default Re: vtec solenoid help
Did you get the actual code number from them, like "P1259" or something. If not go back and get the actual code.
Without that, pretty much just guessing at the issue and possible fix.
Guessing = wasted $'s
Old Feb 21, 2016 | 03:12 PM
ninjs's Avatar
Sorry code is P1253
Old Feb 21, 2016 | 03:34 PM
ninjs's Avatar
Error code P1259 definition is code P1253
Old Feb 22, 2016 | 12:29 AM
holmesnmanny's Avatar
check to see if you have any dents in your oil pan, sometimes the dents prevent full oil pickup from the oil pickup which causes it to throw a code
If that checks out ok, then pull the vtec solenoid and see if the metal mesh filter is clogged up.
If it's clean, it's likely the vtec solenoid has just gone bad. It doesn't happen often, but it does happen. It would be wise to get all the orings and gaskets for the vtec solenoid as well.
Old Feb 22, 2016 | 06:00 PM
user456101's Avatar
You might try changing the oil and using fully synthetic oil. If it is just clogged up some it might clear it out. Taking the solenoid off requires taking off several things so that you can get to it - there are bolts at the top that are easy to access which makes it look easy, but there are also one or a couple of additional bolts on the back down low that are not at all easy. You have to take off the air intake, some water hoses etc. Bushougoma has a YouTube video on how to do it. It is not really for the faint of wrench but it can be done with just some basic hand tools and socket wrenches.
Old Feb 25, 2016 | 02:39 PM
Kevin D's Avatar
As dumb as it sounds, the most common vtec solenoid problem is low oil. I did not realize I had an oil leak at the pan and got the vtec code and the engine sputtering at about 3500 rpms. Went to all the trouble of chasing down the OEM gaskets for it, pulling cleaning and changing the solenoid only to realize it was low oil. Slapped head.
Old Feb 26, 2016 | 02:53 AM
Are you the OP but you forgot your password or something ?
Old Feb 26, 2016 | 06:34 AM
Kevin D's Avatar
No. Just relaying my experience with same gen and P code and what solved it.
Old May 7, 2022 | 09:50 PM
driver333's Avatar
So all you did was change the oil pan gasket and p1259 went away?
wht92teg
Honda Civic (2001 - 2005)
Jan 7, 2013 04:06 PM
b16bavital
Nov 28, 2007 05:31 AM
archer806
Sep 1, 2006 07:44 PM
gsr30035hatch
Feb 28, 2006 06:12 PM
